Go Back   Automotive Forums .com Car Chat > Chevrolet > Caprice
Old 08-13-2008, 09:31 PM   #1
bhw33191
bhw33191's Avatar
Send a message via AIM to bhw33191
Body work finished
I had to seal around the welds with body sealant cause my welder wasn't working right and it was burning right through in some spots. I also couldn't weld that close to the window. But it won't be seen anyway and all i care is that the trunk doesn't leak.
'83 Caprice Classic LM1 (truck) 350 swap. about 200HP, 305 ft/lbs..for now.
-- 65,000 original miles --
bhw33191 is offline   Reply With Quote
Old 08-13-2008, 11:24 PM   #2
silicon212
Confoundingly Lucid
silicon212's Avatar
Send a message via ICQ to silicon212
Re: Body work finished
Looks better ... but for a more lasting repair, use sheet fiberglass and resin. It's a little more work, but yields a more permanent repair. The first large bump you hit might dislodge this. You are on the right track, however. Your repair will be better if you used some sort of screen under the Bondo - did you do this?
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
silicon212 is offline   Reply With Quote
Old 08-14-2008, 02:50 AM   #3
mike561
looks good, you MAY get a few drips here and there, i was able to seal off the pass side but i still get some drips on the driver side after a hard rain
2006 Chevy Cobalt LS
mike561 is offline   Reply With Quote
Old 08-14-2008, 10:00 AM   #4
bhw33191
bhw33191's Avatar
Yeah i know. But at least when it rains i won't have a rushing torrent emptying into my trunk anymore.
Old 08-14-2008, 10:07 AM   #5
bhw33191
bhw33191's Avatar
Yeah i did this myself. And i did use fiberglass as my first repair a month ago and it didn't work out too well cause it drizzled that night which i didn't know and it was enough to make it not dry and screw it up. I put another layer over that and it was just a mess so i ripped it out. But i figured that repairing it with metal would be more permanent though? I mean i did weld it in place like i said so i dunno how a bump could dislodge that. I had a big hole over my fuse box too and i used fiberglass for that and it worked just fine though.
Old 08-14-2008, 12:13 PM   #6
silicon212
Confoundingly Lucid
silicon212's Avatar
Oh, is that a metal patch? Sorry, it looked like Bondo with clear hardener. If it's metal, that's the best way to do it provided you removed all of the old rust (this actually applies toward ANY repair). In that case, it looks fine.
Old 08-14-2008, 06:24 PM   #7
CD Smalley
Whew! silicon212 thought for a second I was going to have jump in here and correct you about using fiberglass over steel.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
CD Smalley is offline   Reply With Quote
Old 08-14-2008, 06:51 PM   #8
craig34
craig34's Avatar
Nice clean caprices in the pics guys.
craig34 is offline   Reply With Quote
