| Latest | 0 Rplys |
06-26-2008, 02:29 PM | #1 | |
Need Help!
I have a 2000 Dodge Ram Van 1500. It has developed an intake gasket leak, but would still start. A month after that, it would click... but wouldn't start. A few weeks after that, I tried to jump it again... and nothing happened. Not even a click. Nothing works on it now, not even the automatic locks. I'm not sure if it's a new battery I need, or if there is a deeper issue. I don't have money for a mechanic, so I'm on the do-it-yourself route. Any advice would be greatly appreciated!
06-26-2008, 09:22 PM | #2 | |
Re: Need Help!
First thing to try is to clean and then tighten your battery connections.
06-27-2008, 12:53 PM | #3 | |
Re: Need Help!
If the intake manifold gasket is leaking its possible that you might have gotten some coolant in a cylinder. The intake gasket also seals coolant passages between heads and manifold. That could cause the engine not to turn over. I hope that's not the problem here, but check your coolant level too, if low at all, pull all the spark plugs and see if it will turn over (may need to use jumper cables if the battery has gone dead). Cranking it like this will remove most of any coolant from the cylinders that it's in. Get as much out as you can in this manner. Then with the plugs still out, shoot a little engine oil into the affected cylinders - enough to coat everthing to resist any rust buildup, and crank it over a little more. Then also check your engine oil level. Sometimes a leak like that will send coolant into the oil pan, if so change the oil and filter. Leaving it for any time could be bad news - corroded cylinder wall and engine frozen up. Repair the bad gasket before any driving.
