| Latest | 0 Rplys |
WIP - Motorbikes Post topics for any "Works In Progress" motobikes projects in this sub-forum. |
#1 | |
Ducati 999 Special
Hi there, this is my new proyect, a New-Ray 1/12 Ducati 999:
![]() ![]() I found this picture in internet and I inmediatelly wanted to tune my bike. ![]() But later I tought I can do better, changin the regular swing arm to a single sided one, and more agressive paint: ![]() Im going to use a part of the fairing from a Ducati Supersport 1000, because the 999 fairing is too flat: ![]() I allready made the sketches of the single sided arm and the necesary modifications, because the rear brake and traction, I havent decide if use a tubular swing arm or monocoque tipe, I have to bend the rim spokes to fit the new swing arm: ![]() ![]() This is the frame anf fork: ![]() These are the parts to modify: ![]() I saw a sketch from when ducati was planning to release the sport classic concepts, like paul smart replica: ![]() And Im thinking in paint the bike like that, I dont know yet. Here is my sketch: ![]() I allready made the main arm: ![]() It came from a broken sunglasses, I liked the oval shape: ![]() Next step is to cut the swing arm: ![]() The technique for bending the rim consit in use a lighter, make circular movement under the rim, and then press it against an objet that has the distance I need to bend: ![]() There it is, a rim for single sided arm: ![]() And a quick check out: ![]() Next step is to complete the swinr arm structure, it is similar to the ducati mh900e and monster st4: ![]() Here in mexico is hard to fin materials, so I have to use anything, to get a thin tubing, I got it from a candy: ![]() Here is the rear view: ![]() I added primer to find imperfections, I havent decided if paint it yellow or the paul smart version: ![]() ![]() Next, I cutted of the bottom of the fairing, now I have to make the parts fit: ![]() ![]() To paste really hard two pieces, I use krazy and sodium bicarbonate, it makes a really strong union ans is sandable: ![]() Here is the two parts glued and with primer, the union was perfect: ![]() And here is with the ducati yellow: ![]() Icutted off 3mm to the forks to maka the front end lower: ![]() Here are the basic paint pattern: ![]() The bike getting togheter again: ![]() ![]() I added a anti heat cover made with thin aluminum sheet: ![]() Here are the parts with grille inserts: ![]() ![]() ![]() ![]() ![]() Really close to the sketch: ![]() More pictures: ![]() ![]() Desmosedici type exhaust pipes: ![]() Radiator grille: ![]() The monoarm: ![]() With her original sister: ![]() ![]() ![]() ![]() And more pictures: ![]() ![]() Another unique model for my shelves! ![]() ![]() Last edited by blazee; 02-12-2009 at 06:59 PM. |
#2 | |
Re: Ducati 999 Special
Looks like a good idea! I hope it works out for you.
Mark |
#3 | |
Really ingenious work you've done... With some more cleaning before painting, I believe you'll have a handsome model.
Too bad Tamiya is not producing more Ducati kits. |
#4 | |
Thanks, yes tamiya hasnt released new models, I really wish to build the mh900e or the multistrada, we will have to wait.
But thats something good in some way, if I get a tamiya kit I try to build it as close as I can to the real model, instead If I saw a New-ray model in a store I inmediatelly purchase it and in my head I start to thin what modifications to do. |
