Go Back   Automotive Forums .com Car Chat > Chevrolet > Astro > M Bodies
Old 02-26-2008, 08:23 AM   #1
brcidd
brcidd's Avatar
CMPFI "W" Engine Leak Diagnosis Documented- Video and Photos
I had a neighbor bring me his '92 "W" engine van last night. He said it gets really hard to start- he has been told by another mechanic that he needs to replace the regulator.
Symptoms: Van will crank for 10 seconds or more until it starts- Van will restart immediately when warm- but wait ten minutes and you must crank it awhile- it also runs rough for a little while after it does finally start- runs fine otherwise.
There has been so much talk about fuel pressure measurement and leaking into the top of the engine- I could not help but document some things- for future reference
So I do the first test- the fuel pressure and pressure decay measurement. In the video below- I simply turn on the ignition for 1 second and shut it off- notice the pressure rise and fall- the pressure decays about 1 psi per second- which is a sure indicator of a leak--The pressure should rise to about 61 psi and hold above 50 for 5-10 minutes to pass this test.
Fuel Pressure Gage Reading
Now that I know this- and the fact it is hard to start, I know there is a leak under the upper plenum- so I remove it and see the actual leak location and leak evidence...
Now - Here is a labeled photo- to explain a little better.
And Lastly- you can see the leak spraying in this video....
Plastic Line Leak Spraying and Cleaning the Plenum
I hope this helps explain to those who have these symptoms and are not sure what to do.
The plastic pipes are available separately for around $50- it is commonly referred to as the "Nut Kit" - this is what I will replace. The "Spider Assembly" or regulator assembly is the high dollar item- usually $300+, and can be replaced at the same time-- I consider it optional- based on the owner's consent....
I hope this helps some of you- I sure would have liked to have seen something like this on my first time doing this repair......
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
brcidd is offline   Reply With Quote
Old 02-26-2008, 07:40 PM   #2
CD Smalley
Re: CMPFI "W" Engine Leak Diagnosis Documented- Video and Photos
Awesome post!
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
CD Smalley is offline   Reply With Quote
Old 02-29-2008, 11:37 AM   #3
tony4jesus33
tony4jesus33's Avatar
Thanks for posting this, I fixed my van and she is running great. I changed the Fuel Return Lines "Nut Kit" and put New AC-Delco Platinum Spark plugs. I appreciate this site very much and I will refer other Astro-Safari Owners to deal with their Van issues.
Take Care of the Heart with Wheels with TLC, and it will run a life-time!!!! Author: Myself!
Vehicles Owned:
1977 Ford Maverick
1978 Ford LTD
1987 Buick Century
1985 Datsun 510
1985 Buick Regal
1987 Buick Regal
1980 Chevrolet Impala
1983 Buick Regal
1988 Ford LTD
1989 Nissan 200
1985 Buick Regal
1986 Buick Regal
1988 Chevrolet AstoVan
1992 Toyota Corolla FX-16
1988 Plymouth Reliant
1987 Chevrolet MonteCarlo LS
1995 Chevrolet AstroVan-Current
1996 Ford Ranger-Current
tony4jesus33 is offline   Reply With Quote
