| Latest | 0 Rplys |
Let's get Technical! Discussion for hardcore in-depth motor heads! |
11-23-2007, 11:11 PM | #1 | |
i really need help bad
i put in at d16y7 and i had to use the d15b2 intake manifold but anyways its idleing up and down and doesnt quit even when it warms up can someone help me out
11-24-2007, 10:08 AM | #2 | |
Kind of a Big Deal
Re: i really need help bad
sounds like a vacuum leak
11-24-2007, 11:54 AM | #3 | |
someone told me that and to use carb cleaner and that didnt work then someone told me that it might be the tps sensor to i just to get it fix
11-24-2007, 03:38 PM | #4 | |
Kind of a Big Deal
could be the IACV or a vaccum leak... check the hoses... clean the IACV with carb cleaner
11-24-2007, 10:27 PM | #5 | ||
whats the iacv |
11-24-2007, 10:53 PM | #6 | |
Kind of a Big Deal
intake air control valve
11-25-2007, 10:55 AM | #7 | ||
alright weres that located |
11-25-2007, 11:54 AM | #8 | |
i took that off and cleaned and it didnt make a diffrents man
11-25-2007, 09:28 PM | #9 | |
Kind of a Big Deal
did you make sure all the vac lines are conneced in the correct spots?
11-27-2007, 12:29 AM | #10 | |
its either the idle control sensor or it could be the idle air control valve. the valve is rights below where the radiator hose meets the water neck. i can check on my crx. but im pretty sure there the same general location. also after you put a new iacv on, let the car run for a minute and if it still isnt right where you want it, just turn the screw on the throttle body back and forth until you get it right where you want it. alot of people dont even know about the throttle screw. if you have any problems just pm me and ill help you out. both of those parts that it could be are stuff you can get at the junk yard because if it works it works it dont matter if its new. the only thing that matters is that you save money.
