| Latest | 0 Rplys |
#1 | |
1st off I would really appreciate someone helping me find a Engine Diagram with the parts labeled/listed. Please and Thank you
Now the problem with my brothers Daewoo Leganza is that its not starting. So far, I took the battery out and got it tested, battery is fine. Did some research and reading to find out the problem isn't the battery, it could be the starter or solenoid contacts. What happens when I try to start the car is.. I turn the key and it clicks once and does nothing ![]() But the one click tells me it may be the solenoid switch going bad or being stuck I need the schematic or diagram of the engine so I can even find the starter and solenoid, im not a car person but im getting into it, gotta start somewhere.. ![]() What are your thoughts on this situation/problem? |
#2 | |
Re: Engine Diagram and Problem Starting
I found the starter
The 2000 Daewoo Leganza Starter is towards the back of the engine, its kinda low but I wouldn't consider it UNDER the car Here is the Daewoo Engine ![]() It took me awhile to find the starter, but Here is a picture of the Engine trying to guide you in the right direction.. Here is a picture from the side pointing at the starter, its dark so sorry, ask for a picture with flash and ill get it for you if your nice And for those of you who dont know what a starter looks like here is another picture, I didnt know the size until I found it but its about 6-8 inches long and a little fatter than your fist ![]() Problem Solved, for now.. ![]() |
