Go Back   Automotive Forums .com Car Chat > Oldsmobile > Intrigue
Old 08-02-2007, 06:51 PM   #1
Paul VanDenburg
2002 olds A/C mode control
Mode control doesn't change vent outlets. Blows air out all vents, no vacuum from the engine. is there a control valve in the engine compartment, can't trace vacuum line in engine compartment
Paul VanDenburg is offline   Reply With Quote
Old 08-03-2007, 04:44 PM   #2
Paul VanDenburg
Re: 2002 olds A/C mode control
Found two holes in the vacuum line near the battery & high amp fuse box. Hope this helps someone later. Paul
Old 08-09-2007, 07:52 AM   #3
NeoSaiyan7
Excuse me Paul. I am having the same problem. Could you please tell me how you fixed it?
NeoSaiyan7 is offline   Reply With Quote
Old 08-09-2007, 12:38 PM   #4
Paul VanDenburg
I spliced in a small peice I got at the junk yard I think the holes were caused by battery acid.
Old 08-09-2007, 06:49 PM   #5
phewop118
Where exactly does the vacuum line run? I am having very similar problems. Defrost barely blows out the defrost vents and many times, i need to cycle through the modes to get it to change at all. I can also hear a faint noise when moving from 0-2 or so mph and stopping - the noise sounds like a vacuum leak. Could you point out where you had a leak? I also had some battery acid leak onto some parts. Thanks.
phewop118 is offline   Reply With Quote
