Go Back   Automotive Forums .com Car Chat > Suzuki > Sidekick
Old 07-10-2007, 11:38 AM   #1
bellew28
92 sidekick surging
We have a 92 sidekick which surges around 2000 rpm. Replaced ECM, 02 sensor, distributor cap rotor & plugs, adjusted tps, adjusted timing, checked fuel pump, no codes in ecm. Check engine light on constantly and will not flash codes. Any ideas would be appreciated. Thanks!
bellew28 is offline   Reply With Quote
Old 09-22-2007, 01:45 AM   #2
spdo
Re: 92 sidekick surging
I am having the same problem with a 1991 sidekick but have no check engin light on, no codes either... did you find a solution?
spdo is offline   Reply With Quote
Old 12-11-2007, 06:19 PM   #3
Crvett69
Crvett69's Avatar
i had a miss/surge in a 92 tracker. no codes from ecu. friend has a spare ecu, i put that in and miss went away, runs real smooth now. funny thing is the ecu i pulled out of the tracker was a rebuilt unit by ASE, either they didn't rebuild it right or something else failed
Crvett69 is offline   Reply With Quote
Old 09-01-2009, 12:32 PM   #4
MAXIMUS_PRICO
sidekicks are known for a couple of things that may cause this one is manifolds that crack over time ,remove heat shield and inspect manifold specially tube #4 also ECU are now to go bad over time too is some capacitors or diodes search ebay for sidekick tracker ecu repair and it explain it there
MAXIMUS_PRICO is offline   Reply With Quote
