| Latest | 0 Rplys |
Engineering/Technical Ask technical questions about cars. Do you know how a car engine works? |
#1 | |
![]() Join Date: Nov 2005
'69 GTO ignition problem
Okay, so my dad has a '69 GTO with a 400 in it. He bought it back in the early 90s and restored it but it has had an ignition problem forever and we can't seem to fix it. It will start up fine and run great, but once you turn it off you can't start it again until it cools off. You hit the ignition and all you hear is a click. Happens every time. He has taken it to many mechanics and they can't figure it out. I'm wondering if any one else has come across a problem like this.
Light'em up ![]() |
#2 | |
AF -Advisor
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2004
Re: '69 GTO ignition problem
It's known as the "heat sink" problem. The starter gets too hot, especially with headers, but not always. Ames Performance and Performance Years both offer heat shields for both the solenoid and the starter. They help. Another approach commonly used is to install a Ford starter relay in between the battery and the starter.
Running too much timing (initial past 12) and too low octane can also make it happen. Was this engine modified for lower compression? If not, it REQUIRES 100 octane, not readily available most places. Sometimes, just installing a heavier battery cable ('0') will fix it. We use high quality welding cable for battery cables in these cars. Hope this helps. Jim |
