Go Back   Automotive Forums .com Car Chat > Mitsubishi > 3000GT/Stealth
Old 04-17-2007, 01:00 PM   #1
2n turbo
4ws/aero
my 4ws and auto aero wing and lip doesn't work on my vr4......n e ideas peeps
2n turbo is offline   Reply With Quote
Old 04-17-2007, 01:27 PM   #2
Linebckr49
Linebckr49's Avatar
Send a message via AIM to Linebckr49
Re: 4ws/aero
how do you know your 4WS doesn't work? the system is only active above 31mph and the rear wheels turn in-phase (that is the same direction as the front wheels) up to 1.5 degrees.
as for the active aero, do a search, this has been asked before. there is a computer that controls both the wing and lip. there are also small plastic pieces within the wing/lip that can break.
read our FAQ, and welcome to AF!
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Linebckr49 is offline   Reply With Quote
