| Latest | 0 Rplys |
02-15-2007, 04:55 PM | #1 | |
91 accord exr won't start, no spark!!!!
Hi all , I need help with my 91 accord exr . I was driving and it died on me , so I put it into park and tried starting it again , it started drove about a block and it died again , this time I could not get it started . I had it towwed home. Since then I could not get it to start ,boosted battery etc. I checked for fuel at the rail, plenty of fuel . I don't have a spark though . So I replaced the ignitor on the distributer , no luck so I replaced the coil , still no luck ,replaced cap and rotor still nothing . tested for spark with a new ngk spark plug still nothing . Anyone have anymore Ideas as this is starting to piss me off. Oh by the way timing belt is fine ! Please any help would be appreciated , THANX guys
02-15-2007, 05:31 PM | #2 | ||
Re: 91 accord exr won't start, no spark!!!!
You never mentioned fuses!
Did you check them. Nex thought would be: timing belt jumped a tooth. Sam
02-15-2007, 08:11 PM | #3 | |
did a quick look at fuses , which one would I be looking at anyway , as for the timing belt I had my buddy starting the car and Iremoved the engine oil cap and I could see the engine trying to turn over . Anyone else have a similar problem
02-15-2007, 08:45 PM | #4 | |
Lactose the Intolerant
Make sure the rotor is turning...some Honda distributors seize and break the bearing in the bottom of the distributor and the cam is not driving the rotor anymore....Worth a look...
02-15-2007, 08:59 PM | #5 | |
is there away to check if the rotor is turning ?
02-15-2007, 09:12 PM | #6 | |
Take off the distributor cap. Could be the ignition switch, main relay, distributor (TDC sensor, crank angle sensor, cylinder sensor), ECU. I recommend you start testing with a meter/test light to see what you are missing that is causing no spark.
