| Latest | 0 Rplys |
Tips and Maintenance Procedures Post helpful tips, maintenance guides and R&R procedures for all Buick models here. |
#1 | |
AF Moderator Elite
![]() Join Date: Feb 2005
The following RPO codes are for LeSabre only. This particular thread is locked from posting, so therefore if you have RPO codes on your LeSabre that are not listed here, PM me with the codes, or submit them Here and the list will be updated as time permits. When submitting, please try not to duplicate codes already listed.
![]() Note: The code and descriptions are sorted numerically first, then alphabetically. 1SD....OPTION PKG 4 12U....SILVER PRIMARY COLOR 17I.....CHARCOAL INTERIOR COLOR 6CL....FRONT LH COMPUTER SEL SUSPENSION 7CL....FRONT RH COMPUTER SEL SUSPENSION 8CW....REAR LH COMPUTER SEL SUSPENSION 87A....GUNMETAL ACCENT STRIPE 9CW....REAR RH COMPUTER SEL SUSPENSION 15E....TRIM COMBINATION, CLOTH, MED SLATE GPAY (E) (91) 20A....STRIPE COLOR, ACCENT, DK ROYAL BLUE (94) 302....TRIM COMBINATION, LEATHER, MED DK ADRIATIC BLUE (1) 30I.....INTERIOR TRIM, MED DK ADRIATIC BLUE (I) (94) 30U....PRIMARY COLOR, EXTERIOR, GRAY BLUE MET (91) A90.... LOCK CONTROL, RR COMPT LID, REM CONT ELEC RELEASE AG1....ADJUSTER, FRT ST, POWER, 6 WAY DRIVER, SPLIT BENCH AG2....ADJUSTER, PASS ST POWER, 6 WAY, SPLIT BENCH AJ1....TINTED WINDOWS AK5....RESTRAINT SYSTEM, FRT SEAT, INFLATABLE, DRIVER AM2....MANUAL PASSENGER SEAT WITH LUMBAR AM6....SEAT, FRT SPLIT, 3 PASS, CTR ARM REST AP9....NET, CONVENIENCE AU0....LOCK CONTROL, REMOTE ENTRY – KEYLESS ENTRY (DOMESTIC) C67....HVAC SYSTEM, AIR CONDITIONER FRT ELECTRONIC CONTROLS C90....LAMP, INTR, FRT AND RR DRS, COURTESY CD2....WINDSHIELD WIPER FLUID INDICATOR CJ2....HVAC SYSTEM AIR CONDITIONER FRT, AUTO TEMP CONT D64....MIRROR I/S, RH, SUNSHADE, ILLUM D74....MIRROR, I/S, LH SUNSHADE, ILLUM D85....STRIPE, BODY SIDE LOWER ACCENT DA0....ARM REST, FRT SEAT, STORAGE DD8....LIGHT SENSITIVE REAR VIEW MIRROR DG7....MIRROR O/S, LH & RH, REM CONT, ELEC, PAINTED DE6....OUTSIDE REMOTE CONTROL FOLDING MIRRORS DH6....ILLUMINATED SUNVISOR MIRRORS FE9....FEDERAL EMISSION CERTIFICATE FE1 SUSPENSION SYSTEM, SOFT RIDE F17....RATIO, TRANSAXLE FINAL DRIVE 2.84 F41....FIRM RIDE/HANDLING SUSPENSION F83....3.05 AXLE RATIO IQ2....PERFORATED LEATHER SEATING INSERTS JL9....BRAKES, POWER FRONT AND REAR DISC, ANTI LOCK JM4....BRAKE, SYSTEM, PWR, FRT DISC, RR DRUM, CAST IRON, K12....CABIN AIR FILTER K34....CRUISE CONTROL, AUT0MATIC, ELECTRONIC K68....GENERATOR,105 AMP L27....ENGINE, GAS, 6 CYL, 3.8L, MFI, V6, HO (3800 SERIES) L36....SERIES II 3800 NORMALLY ASPIRATED ENGINE M13....TRANSMISSION, AUTO 4 SPD, HMD 4T60-E, ELECTRONIC MN3....4T65E 4 SPD AUTO TRANS MX0....MERCHANDISED, TRANS, AUTO PROVISIONS, O/D NF2....EMISSION SYSTEM, FEDERAL, TIER 1 NK5....STEERING WHEEL, STANDARD NF7....LEATHER WRAPPED STEERING WHEEL AND SHIFT KNOB N73....CUSTOM, SPORT WHEELS, VARIANT 4 ORN....PLANT CODE, ORION MI PH3....WHEEL, 15 X 6, ALUMINUM CAST, 115MM BOLT CIRCLE QGZ....TIRE ALL, P205/70R15/N WS R/PE ST TL ALS QNX....P225/60R16 TIRES SLM....STOCK ORDER, PROCESSING CODE T2N....SHAFT, FRONT STABILIZER, TUBULAR T87....LAMP, CORNERING U1L....RADIO, AM STEREO & FM STEREO, SEEK/SCAN, AUTO/REV U75....ANTENNA, POWER, RADIO UB3....CLUSTER, INST, OIL, COOL TEMP, VOLTS, TRIP ODOM, TACH UB7....CLUSTER, INST, OIL, COOL TEMP, VOLTS, TRIP ODOM, TACH UJ2....INDICATOR, ENGINE OIL LIFE UK3....ELECTRONIC SYSTEM, ACCESSORY CONT (STEERING WHEEL CONTROLS) UP0....RADIO, AM/FM, STEREO, SEEK/SCAN, AUTO REV, MUSIC, SEARCH, CASS, CD, AUTO TONE, CLOCK & ETR UV5....DISPLAY , SERVICE REMINDER UV7....INTEGRAL FRONT AND REAR ANTENNA UW6....SPEAKER SYSTEM, 6, DUAL F/D TWEET & WOOF, DUAL EXT V73....ANTENNA, FIXED VH9....ENVELOPE, OWNER INFO MAN WG1....SALES, PROCESSING FOR DR POWER SEAT Y56....GRAN TOURING PACKAGE Last edited by HotZ28; 10-07-2007 at 07:50 PM. |
