Go Back   Automotive Forums .com Car Chat > Buick > Tips and Maintenance Procedures
Tips and Maintenance Procedures Post helpful tips, maintenance guides and R&R procedures for all Buick models here.
Closed Thread Show Printable Version Show Printable Version | Email this Page Email this Page | Subscription Subscribe to this Thread
Old 01-27-2007, 09:02 PM   #1
HotZ28
AF Moderator Elite
HotZ28's Avatar
Arrow RPO Codes - PA's Only!
The following RPO codes are for PA's only. This particular thread is locked from posting, so therefore, if you have RPO codes on your PA that are not listed here, PM me with the codes, or submit them Here and the list will be updated as time permits. When submitting, please try not to duplicate codes already listed.
Note: The code and descriptions are sorted numerically first, then alphabetically.
14 ....TRIM COMBINATION, LEATHER, LT GRAY (2) (92)
14A....STRIPE COLOR ACCENT, LT GRAY (91)
14I.....INTERIOR TRIM , LT GRAY (I) (92)
15E….TRIM COMBINATION CLOTH, SHALE/NEUTRAL (E) (97)
15E….TRIM COMBINATION, CLOTH, MED SLATE GPAY (E) (91)
1SB….OPTION PACKAGE 02
1SE....PACKAGE OPTION 05
1SZ....PACKAGE OPTION DISCOUNT
39U....PRIMARY COLOR, EXTERIOR, DK ADRIATIC BLUE MET (94)
40U….PRIMARY COLOR, EXTERIOR, WHITE (91)
50U...PRIMARY COLOR EXTERIOR, OLYMPIC WHITE (02)
50U...PRIMARY COLOR EXTERIOR, STONE BEIGE MET (02)
57U….PRIMARY COLOR, EXTERIOR, CAMEL BEIGE (91)
642….TRIM COMBINATION, LEATHER, LT BEIGE (2) (92)
643....TRIM COMBINATION, LEATHER, LT BEIGE (3) (92)
649….SEAT BELT COLOR, LIGHT BEIGE (9) (92)
64I…. INTERIOR TRIM, LIGHT BEIGE (I) (92)
6HT….COMPONENT FRT LH COMPUTER SEL SUSP (6HT)
6JR....COMPONENT FRT LH, COMPUTER SEL SUSP (6JR)
6KJ....COMPONENT FRT LH COMPUTER SEL SUSP (6KJ)
75A….STRIPE COLOR ACCENT, RED (91)
789….SEAT BELT COLOR, GARNET RED (91)
78D….TRIM COMBINATION, CLOTH, GARNET RED (D) (91)
78I ….INTERIOR TRIM, GARNET RED (91)
7HT….COMPONENT FRT RH COMPUTER SEL SUSP (7HT)
7HU….COMPONENT FRT RH COMPUTER SEL SUSP
7JR....COMPONENT FRT RH, COMPUTER SEL SUSP (7JR)
7KJ....COMPONENT FRT RH COMPUTER SEL SUSP (7KJ)
87L....SECONDARY COLOR EXTERIOR, GUNMETAL MET (91)
8SN....COMPONENT RR LH, COMPUTER SEL SUSP (8SN)
8SM....COMPONENT RR LH COMPUTER SEL SUSP (8SM)
8SN....COMPONENT RR LH COMPUTER SEL SUSP
8YS....COMPONENT RR LH COMPUTER SEL SUSP (8YS)
9SN....COMPONENT RR RH, COMPUTER SEL SUSP (9SN)
9YS....COMPONENT RR RH COMPUTER SEL SUSP (9YS)
A26....WINDOW, EUROPEAN GLAZING, ALL
A43....MEMORY SEAT ADJUSTER, MIRROR, POWER, DRIVER
A6 ....THEFT DETERENT SYS
A80....ADJUSTER FRT, ST BK, POWER DRIVER, RECLINING
A81....ADJUSTERPASS, ST BK, POWER, RECLINING
A91....PULL DOWN, RR COMPT LID
AG1....ADJUSTER, FRT ST, POWER, 6 WAY DRIVER, SPLIT BENCH
AG2....ADJUSTER, PASS ST POWER, 6 WAY, SPLIT BENCH
AJ3....RESTRAINT SYSTEM, FRT SEAT, INFLATABLE, DRIVER
AK5....RESTRAINT SYSTEM, FRT SEAT, INFLATABLE, DRIVER AND PASSENGER
AM6....SEAT, FRT SPLIT, 3 PASS, CTR ARM REST
AN4....RESTRAINT PROVISIONS, CHILD
AP9....NET, CONVENIENCE
AQ7....SEAT, FRT SPLIT, 3 PASS, 6 WAY ADJ, RECL
AT6....ADJUSTER PASS ST BK, MANUAL, RECL
AU0....LOCK CONTROL, REM0TE ENTRYD D0MIRROR O/S, LH & RH, REM CONT, ELEC, DEFOG, LT
AU4....LOCK CONTROL, SIDE DR, ELEC, AUT0MATIC
AX4....RESTRAINT, CONVERSION SEAT, MAN, EUROPEAN
B36....COVERING, FLOOR MAT, LUGG COMPT
B93....ORNAMENTATION, EXTR MLDG, DR EDGE GUARD
BMD....PLANT CODE FLINT, MI, USA
C57....VENT, FORCED AIR
C67....HVAC SYSTEM, AIR CONDITIONER FRT ELECTRONIC CONTROLS (96+)
C97....ILLUMINATED ENTRY
CD2....INDICATOR, WSWA JAR FLUID
CF5....ROOF, SUN, GLASS SLIDING, ELEC
CJ2....HVAC SYSTEM AIR CONDITIONER FRT, AUTO TEMP CONT
CU5....COUNTRY, SWITZERLAND
D75....HANDLE, O/S, DR
D83....PAINT, MONOTONE
D85....STRIPE, BODY SIDE LOWER ACCENT
D89...PAINT, SPECIAL DÉCOR
DA0....ARM REST, FRT SEAT, STORAGE
DC6....MIRROR O/S, LH & RH, REM CONT, ELEC, LH & RH DEFOG,
D74....MIRROR, I/S, LH SUNSHADE, ILLUM
DD0....MIRROR O/S, LH & RH, REM CONT, ELEC, DEFOG, LT
DD8....MIRROR I/S, R/V, LT SENSITIVE
EXP....EXPORT
E22....HANDLE, ASSIST REAR
F17....RATIO, TRANSAXLE FINAL DRIVE 2.84
F31....UX1 RADIO, AM/FM STEREO CASSETTE EQUALIZER
F41....SUSPENSION SYSTEM, FRT, RR, FIRM RIDE, HANDLING
F79....RATIO, TRANSAXLE FINAL DRIVE 2.97
FE1....SUSPENSION SYSTEM, S0FT RIDE
FE2….RIDE HANDLING
FE3….SUSPENSION SYSTEM, SPORT
FE9....CERTIFICATION EMISSION, FEDERAL
FW2 RATIO, TRANSAXLE FINAL DRIVE 3.06
FX3….RIDE AND HANDLING, AUTOMATIC ELECTRONIC CONTROLLED AAA
G67….LEVEL CONTROL, AUTO, AIR
G69….LEVEL CONTROL, AUTO, AIR, HD
IC2....TRIM INTERIOR DESIGN (C2)
IC3....TRIM INTERIOR DESIGN (C3)
ISZ....DISCOUNT OPTION PACKAGE (VALUE GROUP)
JM4....BRAKE, SYSTEM, PWR, FRT DISC, RR DRUM, CAST IRON,
K05....HEATER ENG, BLOCK
K68....GENERATOR,105 AMP
KA1....HEATER SEAT
KC4....COOLING SYSTEM, ENG OIL
KP2....TIMER, RETAINED ACCESSORY POWER
L27....ENGINE, GAS, 6 CYL, 3.8L, MFI, V6, HO (3800 SERIES)
L67.....ENGINE, GAS, 6 CYL, 3.8L, YFI, V6, SUPERCHARGED
M13....TRANSMISSION, AUTO 4 SPD, HMD
MAE MARKETING AREA, EUROPE
MX0....MERCHANDISED, TRANS, AUTO PROVISIONS, O/D
NA5....EMISSION SYSTEM, FEDERAL, TIER
NB2....EMISSION SYSTEM , CALIFORNIA , TIER O
NF2....EMISSION SYSTEM, FEDERAL, TIER 1
NK5....STEERING WHEEL, STANDARD
NP5....STEERING WHEEL, LEATHER WRAPPED or LEATHER WRAPPED, STEERING WHEEL AND SHIFT KNOB
NW9.... TRACTION CONTROL, ELECTRONIC
OUW....6-SPEAKER SYSTEM, 6, DUAL F/D TWEET & WWF, DUAL EXT
P42....TIRES, SELF SEALINGU
PH3....WHEEL, 15 X 6, ALUMINUM CAST, 115MM BOLT CIRCLE
PH6....WHEEL, 15 X 6, ALUMINUM
PY0....WHEEL, 16 X 6.5, ALUMINUM
QII.....TIRE ALL, P215/60R16 8W R/PE ST TL AL3 94H
QPN....TIRE ALL, P215/70R15/N WS2 R/PE ST TL ALS 97S
R6B....CONTROL SALES ITEM NO. 02
R6F....CONTROL, SALES ITEM NO. 06
R6Z....CONTROL, SALES ITEM NO. 25
R7K....AM/FM STEREO WITH SINGLE CD
T2F....BRAKE PROVISIONS, SPECIAL
T61....LIGHTING, DAYTIME RUNNING
T79....LAMP, FOG, RR
T82....HEADLAMPS, AUTO ON-OFF CONT
T84....HEADLAMPS, RH RULE OF ROAD, E MARK RECTANGULAR
T90....LAMP, SIGNALING & MARKER EXPORT
T87....LAMP, CORNERING
TU8....LAMP, INTR, STOP, HIGH LEVEL ---- DELETE
U03....HORN, NOISE REGULATION
U09....HORN, FOUR NOTE
U18....SPEEDOMETER, INSTRUMENT PANEL (KILOMETER)
U19...SPEEDOMETER,INST, KILO & MILES KILO ODOMETER
U41....INDICATOR, LOW FUEL
U75....ANTENNA, POWER, RADIO
UA1....BATTERY, HEAVY DUTY
UA6....THEFT DETERENT SYS
UB3....CLUSTER, INST, OIL, COOL TEMP, VOLTS, TRIP ODOM, TACH
UJ2....INDICATOR, ENGINE OIL LIFE
UK3....CONTROL, STEERING WHEEL ACCESSORY
UL2....FREQUENCIES, EUROPEAN RADIO
UM3....RADIO, AM STEREO-FM STEREO, SEEK/SCAN, COMPACT
UM6....RADIO, AM/FM STEREO, SEEK/SCAN, AUTO REV CASS,
UN4....TAPE CARTRIDGE DELETE
UN6....RADIO, AM/FM STEREO, SEEK/SCAN, AUTO REV MUSIC
UQ8....SPEAKER SYSTEM, 4, DUAL FRT EXTD RGE, DUAL EXTD RGE
UV5....DISPLAY , SERVICE REMINDER
UW6....SPEAKER SYSTEM, 6, DUAL F/D TWEET & WWF, DUAL EXT
V2G....CREDIT FULL FUEL FILL
V73....ANTENNA, FIXED V73.....VEHICLE STATEMENT, US/CANADA?
V78....VEHICLE STATEMENT DELETE
V92....TRAILER PROVISIONS
V97....VEHICLE PREPARATION, EXPORT
VC1....LABEL PRICE/FUEL ECON, COURTESY DELIVERY
VC4....LABEL PRICE/FUEL ECONOMY, PUERTO RICO AND VIRGINISLANDS
VC5....LABEL SHIPPING, EXCEPT U.S., U.S. POSSESSIONS, OR JAPAN
VG9....PROTECTOR, WAX, EXTERIOR BODY
VH5....PLATE, VEHICLE IDENTIFICATION
VL4....LICENSE PLATE, FRT MOUNTING PKG, EEC
VV1....FUEL, UNLEADED GAS
VG8....VEHICLE, BUYER NOTICE LABEL
W73....ENTERTAINMENT SYSTEM OPTION J
Y56....MERCHANDISED PKG, GRAN TOURING
Y67 ....DISPLAY , REMINDER PACKAGE
YF5....CERTIFICATION, EMISSION, CALIFORNIA
ZAA....TIRE SPARE, COMPACT
HotZ28 is offline
Closed Thread
