Go Back   Automotive Forums Car Chat > Pontiac > Grand Prix > Tips and Maintenance
Tips and Maintenance Post helpful tips, maintenance guides and R&R procedures here (for both Pontiac Grand Prix and Oldsmobile Intrigue)
Old 01-14-2007, 09:17 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Radio Backlight Lamp Replacement '97-'03
There is a mini-lamp for the radio time display which burns out. The dash panel and radio have to be removed to replace it. The part # is 16208443 available at the dealer. Cost approximately $8.00. Substitute bulbs are available at Radio Shack and mentioned in the R&R procedure below.
Click here
And here is a basic procedure to get the radio out:
Click here
Timeslip 08/12/06
AF Community Guidelines
Old 01-30-2008, 09:47 PM
davehecky davehecky is offline
Re: Pontiac Radio Backlight Lamp Replacement '97-'03
I bought my bulb from ebay, user (ann_abelle123) which is made by GM. It worked perfect and shipped out super fast. It only took a couple of minutes to install. The bulb was around $20 bucks.
Old 04-18-2008, 06:19 PM
gpgtowner gpgtowner is offline
Re: Radio Backlight Lamp Replacement '97-'03
The instructions state that the bulb has to be soldered in place. Is that the only way to install a new bulb?
Old 04-19-2008, 01:25 PM
Most of them do not have to be soldiered. Like the grand prixs all the way up to year 04. Dave
Old 04-19-2008, 07:53 PM
Thanks Dave,
And so the obvious follow up question is how are they installed. I just want to know before I take my dash all apart. I really appreciate the advice and the pictures. They have helped immensely.
Old 04-22-2008, 03:38 PM
They just twist right in. I bought mine from (ann_abelle123) on ebay. Just search the items shes selling. They are brand new from the dealer AC Delco. Later
Old 04-22-2008, 03:41 PM
winty03 winty03 is offline
Ya I know they twist in using the brown plastic socket. I tried a new gm bulb and then also pulled the blub out and used a replacement suggested in the how to and solder it in and still no light. I am going to try to hook it up directly to the 12 volt battery and see if the bulbs are good.
Old 04-22-2008, 04:47 PM
I bought mine and it came with the plastic casing around the bulb. No soldering
Old 11-17-2008, 07:51 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Anyone know why this tech article doesn't work anymore?
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 05-01-2009, 10:22 AM
iceman2 iceman2 is offline
There is an excellent video on youtube that shows the procedure:
http://www.youtube.com/watch?v=uWzXaPL8MgQ
Be very careful with the long pins that go back into the orange recetacles.
Old 05-06-2009, 09:49 PM
lance_kidd lance_kidd is offline
I am very happy to hear about this bulb. I this thread is kind of old, but my radio at first in my 01 Grand Prix stopped turning on and off easily. I guess it's the little contact or rubber piece under the on/off button that's messed up. Can that be fixed?
Anyway, I called the junk yard and they have one that looks good and works, but he said the display doesn't work. I'm glad to know if I have to, I can get it and probably fix the light.
