| Latest | 0 Rplys |
Tips and Maintenance Post helpful tips, maintenance guides and R&R procedures here |
#1 | ||
out saving the world
![]() Join Date: Jul 2005
This is for 99+ N-Bodies
Which includes; 2.4L 4 cyl, and the V6 3.1 & 3.4L; Alero(99-2000), Cutlass(97-99), Grand AM(99-2000), Malibu(97-2000) - On the V6 its behind the TB, cant miss it. - On the 4 cyl the EGR is located off the side of the intake. *You will have to remove the air intake tube and air duct around the TB to get to it. *Not all 4 cyl have EGR's, see list below. Quote:
![]() V6 EGR ![]() 4 cyl EGR - Disconnect the elec connector from the EGR. - Using a voltmeter Probe terminal #5 on the electrical connector with the positive (on the harness side), and apply the ground to the engine. - Turn the key on, On the V6 battery voltage should be present, - if not check the curciuts(wiring) from the PCM to the EGR. - If the curcuits are good have the PCM checked by a dealer. - On 4 cyl models battery voltage will only be present when the PCM is controling the EGR. - With plug still disconnected, probe # 4 with the posistive, and connect the ground to # 2. - Turn on the key, you should read approx 5 volts. - If not check the wiring, if they are good same as above, contact a dealer. -- To test the EGR valve, use an Ohm meter to check for continuity of the EGR valve position and Egr solenoid coil. - Check terminals #2 & #4(EGR sensor), and acrossed terminals #1 & #5(egr coil sol). - If either check reveals an open circuit, replace the EGR valve. -To remove simply unplug wire harness. -Remove 2 mounting bolts. -Remove old gasket(us a scrapper to clean of any old gasket), and replace with a new gasket. Also make sure the port/passages are clear and not clogged with carbon build up. If not clear this can cause false DTC readings. -Install in the reverse procedure.
1999 Grand Am SS 3.4 OHV ![]() Last edited by xeroinfinity; 04-15-2007 at 11:43 AM. |
