Go Back   Automotive Forums .com Car Chat > Chevrolet > Monte Carlo
Old 09-26-2006, 12:05 AM   #1
1987ss
1987ss's Avatar
87 ss tranny install?
i just had the tranny rebuilt and i was told to properly adjust the detent cable.. could someone tell me how? its a 87 ss with a 200r4 tranny
1987ss is offline   Reply With Quote
Old 09-26-2006, 12:36 AM   #2
silicon212
Confoundingly Lucid
silicon212's Avatar
Send a message via ICQ to silicon212
Re: 87 ss tranny install?
It's actually called a TV cable as it controls not only detent downshifts, but line pressure modulator functions as well.
At the base of the carb, on the driver side of the car, you will see where the TV cable adjustment is - it's the "D" shaped tab:
Press the "D" shaped tab (where it says "Press Here") hard with your thumb and pull the cable back to the firewall as far as it will go (the plunger will be flush with the adjustment housing at the front), then release the "D" shaped tab, let go of the cable and then using a screwdriver, open the throttle as far as it will go. You should hear some clicks - it might even sound like a rattlesnake - but once you open the throttle, you can close it again and the cable is now adjusted.
This procedure is used on both the 2004R and 700R4 transmissions.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Last edited by silicon212; 06-14-2010 at 09:59 PM. Reason: in italics, edited for clarity.
silicon212 is offline   Reply With Quote
Old 09-26-2006, 09:34 AM   #3
1987ss
1987ss's Avatar
thank you!!
Old 09-28-2006, 02:02 AM   #4
1987ss
1987ss's Avatar
is what we did was opened up throttle and held it open and then pushed button.. is that wrong i know i sound like a dumb ass but im frustrated when you drive it its a rough shift in to second and the kick down dosent work when you kick it down... i hope its us and not the rebuilder
Old 09-28-2006, 02:09 AM   #5
silicon212
Confoundingly Lucid
silicon212's Avatar
Yes, that's wrong. When you press the button down, the reaction of the cable will be to pull toward the carburetor. It needs to be pulled toward the firewall.
You press the button, then pull the cable back - WHILE THE THROTTLE IS CLOSED. Now, you open the throttle all the way at the carb to return the cable to its proper resting position within the adjuster.
If the cable is maladjusted, it could be death to your transmission - and a quick death at that.
Old 09-28-2006, 09:32 AM   #6
1987ss
1987ss's Avatar
thanks for your help!!!!! do i remove it from the mounting bracket? do i unhook it from carb or tranny? im confused i guess ive never touched one before !! and again thanks for your help
Old 09-28-2006, 10:55 AM   #7
silicon212
Confoundingly Lucid
silicon212's Avatar
No, do not remove anything.
