| Latest | 0 Rplys |
#1 | |
ECM Motor Fuse
Help
My ecm motor fuse keeps blowing and shutting down the motor on my 95 blazer, I changed the alt but that is not the problem any sugestions |
#2 | |
Re: ECM Motor Fuse
I can tell you what not to do!! My ’95 was blowing the ECM 20 amp fuse while I was on the road. I kept replacing it trying to get back home. I ran out of 20 amp fuses, so I put a 30 amp in. It didn’t blow the 30 amp, but the engine shut down as it did when blowing the 20 amp and I had to be towed back in. It’s not showing any codes, so all I can do is troubleshot with the GM shop manual. I replaced the crankshaft sensor with a new one, replaced the VCM with a used one and it’s still a no start situation, with no spark. I’m still looking for the problem. If and when I find it I will post it.
#3 | |
Re: ECM Motor Fuse
Oxygen sensor might be shorted. Will cause very rough idle to the point it will cut off. check all of your engine grounds including the ground for your trans.
#4 | |
AF -Advisor
![]() Join Date: Sep 2003
Re: ECM Motor Fuse
wiring short, also,
IT IS COMPLETELY RETARDED TO REPLACE A 20 AMP FUSE WITH A 30 AMP TO STOP IT BLOWING. All you will start is a fire.
1995 Factory Blazer Service Manual for sale, PM if interested. |
#5 | ||
AF - Advisor
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Sep 2005
Re: ECM Motor Fuse
What engine code and what PCM and also what ecm fuse? If TBI with 2 Injectors in it check for a pinched wire under air filter adapter on TBI. MT
#6 | ||
Re: ECM Motor Fuse
#7 | ||
Re: ECM Motor Fuse
#8 | ||
Problem?
![]() Join Date: Dec 2004
Re: ECM Motor Fuse
#9 | ||
Problem?
Re: ECM Motor Fuse
The next person to make a disrespectful comment to another poster in this thread gets 3 days off. The threadstarter needs help, don't piss on his thread. |
#10 | |
GM S-Series Mod
![]() Join Date: Aug 2005
Re: ECM Motor Fuse
im guessing either a short in that circuit or a bad ground to the ecm
2000 Chevy Blazer ZR2 Performance Mods: Numerous Suspension Mods: Some, but not enough Exterior Mods: Just Right 1987 Buick Turbo T Dark Red Low 11 sec sleeper ![]() .030 4.1 block, PT6262E, & other odds and ends.... My Cardomain |
#11 | |
AF -Advisor
Re: ECM Motor Fuse
Ground or some of the wiring has worn through somewhere.
#12 | ||
Re: ECM Motor Fuse
#13 | |
Re: ECM Motor Fuse
a year ago my 97 would run like crap and shut off also. Im not sure if its the same system but. I would get an o2 post cat code. SO i replaced it and nothing happen. Turns out where all the wires come up to the big harness in the back of the engine bay. The wires wore though the Loom and were slowly one by one being cut on the back on the engine as the motor moves slighty. I used a zip tie concoction to hold the wires away from everything. If u cant find anything i would start by looking around that area. around the back of the motor and the fire wall.
http://www.cardomain.com/ride/783126 |
#14 | |
Registered Offender
![]() Join Date: Mar 2006
Re: ECM Motor Fuse
HINT: On a '95, the ECM fuse may also power the fuel pump.
