Old 07-10-2006, 01:31 AM   #1
ajthomas75
Opinions on best Photoetch Nut and Bolt sets?
Hi Guys,
The title pretty much speaks for itself - I'm after opinions of the best photoetch Nut and Bolt sets for general detailing. I'm quite curious about the rubber backed photoetch sets - are they any good ? Are they sticky backed so no glue is required ? I've never used them before, only used normal PE. If the rubber backed ones are any good, are there bolt sets which are rubber backed ?
Guess after all that the title doesn't really speak for itself does it
Thanks in advance for the help.
Adam.
ajthomas75 is offline   Reply With Quote
Old 07-10-2006, 02:33 AM   #2
sjelic
sjelic's Avatar
Re: Opinions on best Photoetch Nut and Bolt sets?
Good thing about those rubber backed ones is that you dont have to trim them, they are perfectly clean and perfect when glued on place, they are not self adshive so glue is required, I have Scaleracecars ones and I am very happy with them.
Bad thing is that it is a bit tricky to detach them from that rubber thing and they are so small that you can lose them in no time.
But if you ask me that are the only ones I want to use, those regular PE parts (without rubber back) are extrimly hard to trim.
Sasa Jelic
SCALEMAKERS
sjelic is offline   Reply With Quote
Old 07-10-2006, 03:21 AM   #3
BugZilla
Authorized Vendor
BugZilla's Avatar
Hey Adam,
Replicas & Miniatures, Scale Motorsports, Detail Master/ Model Car Garage and SRC all make nice Nut and Bolt sets. R&M are rubber backed as well, I have had pretty good luck with those. I usually use a trimmed down Grabit Stix from SMS and the tip of a knife to get them loose and hold the part. Then I just place a drop of glue on the part and hold it in place for a few seconds. Once the glue dries, it comes right off the sticky stix.
Dave
BugZilla is offline   Reply With Quote
Old 07-10-2006, 04:40 AM   #4
mickbench
mickbench's Avatar
Originally Posted by BugZilla
Hey Adam,
Dave
You don't by any have pictures of these, and do you sell them? I've got the SMS ones, and they are nice, but too large in places... I've heard the MCG set are a bit smaller..
also, I've read that if you cut a section of the flet, and drop in lacquer thinner, the rubber backing melts off, leaving the P/E behind, ready for attaching..
and I always use a toothpick, with a bit of water on the end.. works everytime..
mickbench is offline   Reply With Quote
Old 07-10-2006, 08:18 AM   #5
Decs0105
Decs0105's Avatar
here are some pictures
ModelCarGarage, very good if you need small ones (1/12,1/20)
ScaleMotorsport, very good if you need big ones (1/12, maybe in some cases 1/20 but normally they are way to big)
Perfect Parts, they look nice but need some cleaning after removing, many different sizes and shapes, this is actually from the McLaren MP 4/6 set but they also sell Nuts, Bolts and Washer sets seperate!
Decs0105 is offline   Reply With Quote
Old 07-10-2006, 08:40 AM   #6
BugZilla
Authorized Vendor
BugZilla's Avatar
Here is a picture of the .055" set, it shows up the best. The other sizes are,
.014", .020", .031" and .041". Prices vary from $3.95 to $8.95. I need to get some new pictures of them up on the site.
Old 07-10-2006, 08:50 AM   #7
sjelic
sjelic's Avatar
And the SRC ones
Some are extremly small
Sasa Jelic
SCALEMAKERS
Old 07-10-2006, 09:17 AM   #8
mickbench
mickbench's Avatar
Oh,
Wish I’d known about some of these, I got the SMS version for my CLK GTR, and they are way too big. Be good for 1/12 scale bikes, but too large for 1/24, which is a shame… Cost a few quid as well..
The MCG and SCR ones look good.. MCG look to be just what I need, damn… More money spent.. why is this hobby such a bank balance drainer..??
Old 07-10-2006, 10:56 AM   #9
ajthomas75
The MCG ones look like the ones to go. Look like they give the most variety in one set. I think I'll have to put an order in for a couple of those from you Dave in a few days.
Also Dave, what the quality of the R&M Resin Bolts RM48 like ? Are they a viable alternative to Sakatsu bolts or do they not even compare ? How much clean up is required ? and what's the size of these ?
Thanks,
Adam.
Old 07-10-2006, 03:30 PM   #10
600sel
600sel's Avatar
Where are these nuts, bolts and washers used for? Anyone has a picture?
600sel is offline   Reply With Quote
Old 07-10-2006, 06:11 PM   #11
freakmech
freakmech's Avatar
Send a message via AIM to freakmech
Hey guys just a little tip for you. If you use a q-tip and a little paint thinner you can easily remove the nuts and bolts as it breaks down the adhesive material used to hold the parts on. much easier then the xacto space launch method, of course this works for the rubber backed ones only.
Friends dont let friends buy die-casts...
"If it can't run 24hrs., it aint sh!t...." -me
freakmech is offline   Reply With Quote
Old 07-11-2006, 04:25 AM   #12
Decs0105
Decs0105's Avatar
I have no idea what your're talking about...
Old 07-11-2006, 12:54 PM   #13
racer917
racer917's Avatar
Hi ajthomas75,
I find that the SMS and MCG fit all my needs. The sms might be a bit too large for most 1/24 applications, (but ok for some), but are just right for 1/12 cars and bikes. You get different head types, phillips, slotted, rivets. The mcg are perfect for 1/24 and 1/43 and even certain 1/12 applications, also with different head types. I also have the SRC sets but have yet to use them, looks good though. Those come in scales from 1/43 to 1/12. All 3 of these go a long way as each "sheet" has +500 pieces.
racer917 is offline   Reply With Quote
