| Latest | 0 Rplys |
#1 | |
![]() Join Date: Dec 2005
Balljoints and torsion bar
Hey, I'm about to yank my balljoints (one tire has worn severely on the inside track, as well as the steering being loose, I figure I might as well change them out) and had a quick question. If I support the lower control arm with a jack will I be ok to pop out the ball joints without having to undo the torsion bar? My chiltons says to release tension on the torsion bar and I really don't want to mess with anything I don't have to (especially important suspension components that are working fine as they are). This is my first truck with torsion bars in the front so I just wanted to double check nothing would explode in my face when popping out the balljoints. Thanks
#2 | |
Re: Balljoints and torsion bar
You should be fine with a jack underneath...as long as your shocks aren't rusted to hell they should keep the tortion bar from taking out your kneecaps. Don't try to do it without removing the CV like I did--the chilton's manual is less than accurate for this. I also found it easier to reinstall the bottom one first. Try searching the blazer forum, there should be a good post with pictures and everything.
#3 | ||
#4 | |
The Haynes manual says to just put a jack under the lower control arm and leave it there during the entire operation.
#5 | ||
#6 | ||
#7 | |
Problem?
![]() Join Date: Dec 2004
This may help:
http://www.automotiveforums.com/vbul...d.php?t=545573 |
#8 | ||
#9 | |
The RustBuster
![]() Join Date: Feb 2006
On a '98 Blazer? Those are probably the original joints...so grab your chisel or die grinder. I'm dreading the same thing. 152k miles on my '96 Jimmy 4wd and the joints/bushings/steering coupling are shot. Found a Campbell-Hausfeld die grinder at Wal-Mart for $20 and working on an urethane replacement for the steering coupling disc (see other forum thread @ http://www.automotiveforums.com/vbul...d.php?t=576450)
To reiterate what's been said, I found my deep socket in the special tools section of Advance Auto parts for $19. I also ended up buying a 3' length of iron pipe from the hardware store for leverage in getting that hub nut off. I bought it big enough to slip over the handle of my torque wrench, making it easier to retorque it down when it's all done. Good luck!
Current Garage: 2009 Honda CR-V EX 2006 Mazda 3i 2004 Chevrolet Silverado 2500HD 2003 GMC Envoy XL 2000 Honda ST1100 2000 Pontiac Sunfire Vehicle History: 2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat. |
#10 | ||
#11 | |
The RustBuster
Yes, what Goser said...I guess I wasn't clear enough on using the pipe. I wouldn't trash my torque wrench to get that honkin' nut off, but the pipe makes it easier to tighen it back down when you're done...good luck!
#12 | |
I didn't see it written anywhere but I'll make a note of it here for others tackling this project. YOU NEED AN 18MM CRESCENT WRENCH! No question about it, you NEED one. I lost mine. I just spent an hour in the driveway PAINFULLY removing all but the balljoint nut and the last 2 hub bolts only to realize all my frustration was in vain, you cannot remove the balljoint nut or the last 2 hub bolts with a socket, no matter what size the socket. Maybe if you have a special miniature wobble or something, which I don't have. Get an 18mm wrench and save yourself the headache ahead of time. Off to the parts store again for me...
#13 | |
Problem?
I just got done changing my balljoints about 30 minutes ago. You can get the ball joint nut with a socket, but it's a PITA. You have to put the jack under the control arm, and raise it up to get a little more clearance. With the hub assembly off you push the half shaft over enough to get the socket on. It's not worth the trouble for taking the old one off, but you'll need to do it like that so that you can properly torque the new one. Make sure that you don't slide the half shafts too far out of the front diff.
Tools used: 3/8 drive rachet 7/16 socket 1/2" drive 18" breaker bar 3/4 socket 7/8 socket 15/16 socket 36mm socket Torque wrench - I stripped the gears putting the 36mm nut back on the last side, so I had to guess on the one. ![]() 10mm wrench 2 x 13mm wrench 7/16 wrench 18mm wrench 13/16 wrench 7/8 wrench 15/16 wrench BFH pickle fork Big ass puller Angle grinder Punch Jack stands 2 1/2 ton SUV floor jack Mini grease gun 2 tubes of grease It took two of us about 4 hours. |
#14 | |
The RustBuster
I'm in the process of replacing the control arm bushings with urethane. So far, I've finished the left side and have to do the right on another weekend.
I unloaded the torsion bar first by marking the bolt's position with a shot of spray paint on one side then unscrewed the tension bolt. Then removed the big axle nut, then the caliper. Then pulled the hub bearing assy loose from the axle, then removed the assy. Removed the shock, unbolted the tie rod and sway bar. I popped the lower ball joint loose then drilled out the upper joint rivet heads and unbolted the upper arm from the frame (mark the position of the camber/caster adjuster cams first). That allowed the upper arm and spindle to come off as one. then you can unbolt & pop the upper joint loose w/o using a pickle fork. This makes drilling out the lower joint rivets a little easier too. Also, make sure you have a hanger to support the free end of the front axle. After replacing the upper joint, reattach the spindle and drive in a new shaft seal (you might as well since you have it apart!). Grease it up and reinstall as the reverse of removal. Hope this helps!
#15 | |
Problem?
With these vehicles, you don't have to drill the rivets out. There is enough room to get an angle grinder in there. It took me about 3 minutes per joint, to grind off the heads.
