Go Back   Automotive Forums .com Car Chat > GMC > Jimmy
Closed Thread Show Printable Version Show Printable Version | Email this Page Email this Page | Subscription Subscribe to this Thread
Old 05-22-2006, 03:32 AM   #1
DelCoch
DelCoch's Avatar
Lightbulb 95 Jimmy Low Batt = No Start - One for the experts
Original owner of a 1995 4x4, 4.3L, 144K miles - Nothing done to engine except replace spark plugs.
This may help someone with the no-start situations.
Recently I had a problem with the battery going dead after sitting a week or so. Then I noticed after sitting a couple days the battery seemed to be low, and although it would still turn the engine over at a good rate the engine wouldn’t start. (I could tell the engine wasn’t turning over quite as fast as it should, but the average person would never be able to tell the difference) The engine would hit a couple licks when I first turned the key, like it was going to start, but it wouldn’t hit enough to start. Further running of the starter did nothing – it wouldn’t even hit a couple more licks. I found by bumping the starter, then turning the key off, then bumping the starter again, and repeating this procedure 4 or 5 times the engine would finally start. Once started it would run and idle fine. I also found that upon charging the battery it would start immediately on first try. I replaced the battery and no more problems.
No doubt, with the 3/4 charged battery, something wasn’t receiving enough current to allow the engine to start. Anyone have any ideas about what was going on – i.e. not enough current to fire the plugs or not enough current to run the fuel pump? What are some of your thoughts?
In case you're wondering if I could hear the fuel pump running, I couldn't - I've never been able to hear the fuel pump run. I know people say the fuel pump should run a few seconds when the key is turned on, but I've never been able to hear it run. Course, my hearing is not what it should be!!
DelC
DelCoch is offline
Old 05-22-2006, 08:09 AM   #2
rlith
rlith's Avatar
Send a message via AIM to rlith Send a message via MSN to rlith
Re: 95 Jimmy Low Batt = No Start - One for the experts
If you're battery is draining after only a couple of days by that much, you have 1 of 2 issues
Either your battery plates are dying
or
You have something drawing on your electrical system when turned off..
Look at all your aftermarket stuff (stereo system, alarm, etc). Meter the voltage and amperage draw.
If you're not finding anything out of the ordinary on those components, disconnect them completely and check draw at the battery. The start checking everyything else.
If all that checks out, it's probably your battery and a battery tester MAY or MAY NOT tell you it's bad. Even if those things say it's good, with all the process of elimination you just did, it's most likely bad..
rlith is offline
Old 05-23-2006, 03:15 AM   #3
DelCoch
DelCoch's Avatar
It doesn't have any aftermarket equipment, and without doubt the old battery was shot, as it's about 5-years old and it failed on the battery tester. I also checked the output of the alternator which was fine.
My questions is: "Why won't it start with a 3/4 charged battery"? The starter still turns it over fast enough that I feel it should start. Like I said, the average person would never be able to tell it wasn't tuning the engine over as fast as it would with a fully charged battery.
Apparently the starter was drawing all the current away from a component that was needed for the engine to start. It appeared not to be getting fuel, as it didn't smoke when it finally started, like it would if the plugs weren't firing and allowing fuel to build up in the combustion chambers. Does the engine have a means to shut off the fuel if the plugs aren't firing?
I can see where this type scenario could lead someone to replace the fuel pump, poppet valves and everything else before discovering the real problem. It's just weird, and it's something others need to keep in mind when trouble shooting. I don't drive it that often and if it hadn't sit for two weeks to allow the battery to go completely dead, I doubt I would have realized the battery was the problem. By driving it every day the battery would stay about 3/4 charged and would cause hard starting or no starting.
DelC
DelCoch is offline
Old 05-23-2006, 07:19 AM   #4
blazee
Problem?
blazee's Avatar
DelC
It's actually a fairly common problem. It is caused by the pump not receiving enough power to produce the proper amount of pressure. There has to be 60 psi for the engine to start right up. With a weak battery the pump can't build up enough pressure during the 2 seconds that it runs when the key is turned on. Cycling the key let's the pump run a few extra times allowing it to build the proer pressure. After the engine starts, the alternator supplies enough power and the engine continues to run.
This problem has caused a lot of people many headaches in cold winters. When either the battery or pump are not performing properly, the problem is made worse by cold weather. This is because the battery's capacity is diminished at cold temperatures. Someone may go out in the morning and their car won't start. They have it towed to a shop. The shop let's it sit for a while, during this time the weather warms up. They go out to work on it and it fires right up. They can't find anything wrong. The customer picks it up takes it home and the next morning, it won't start again.... the problem continues until they get smart and come here asking for help and then one of our members tells them what's wrong.
blazee is offline
Old 05-24-2006, 04:55 AM   #5
DelCoch
DelCoch's Avatar
Lightbulb Re: 95 Jimmy Low Batt = No Start - One for the experts
Ok, Thanks
I thought that was probably what was going on, but I wasn't sure.
I can see where a dishonest or even an honest repair shop could make a lot of money off of it.
DelCoch is offline
Old 05-24-2006, 06:59 AM   #6
ponchonutty
ponchonutty's Avatar
How do you know the battery was 3/4 charged? What value did you use to come up with that???? Anything less than 11.5v can be hard to make some vehicles start. Couple that with a bad cell or 2 and it shouldn't ever start. You don't just need voltage to start a vehicle but AMPERAGE. I've had batteries with over 12v at rest but drop down to 9v. when cranking. It's the same difference when looking at engines. People get all worked up on horsepower but it's torque that gets you going. A lower HP engine with higher torque is usually a better way to go. Don't think so? Just look at diesels.
Silverado Ext. Cab 4x4 z71
Pioneer 4900mp
Orion P6.2 Componet sets front
Orion C63 Coax rear
DirectedVideo 9" all in one DVD with surround
2007 SATURN OUTLOOK AWD XR with full entertainment package
ponchonutty is offline
Old 05-25-2006, 04:26 AM   #7
DelCoch
DelCoch's Avatar
Well, it was more half charged and less than a full charge, and it turned the engine over at a good clip. So, maybe it was 66 2/3 or 80 percent – it doesn’t really matter. The fact is; it was low enough not to start the vehicle, but high enough to turn the engine over fast enough that your wife wouldn’t have noticed the difference in the cranking speed.
I have a load type battery tester and the battery tested about ¾ of what a new and fully charged battery should test at under load. So, go figure.
If diesel engines are such good performers, why don’t they run them at NASCAR??
DelCoch is offline
Old 05-21-2007, 09:12 PM   #8
wendell37
i need a wiring harness map. i have a 1991 olds bravada with serious fuel pump probs. its not getting fire to the pump and i need to see a diagram of the wiring system to check my wires.
wendell37 is offline
Old 05-22-2007, 12:18 AM   #9
ZL1power69
GM S-Series Mod
ZL1power69's Avatar
welcome to af. this thread is now a year old. please refrain from posting in old threads. Feel free to start a new thread in the problem diagnosis section.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
ZL1power69 is offline
Closed Thread
