| Latest | 0 Rplys |
Exterior | Bodykits | Lighting | Aerodynamics Discuss different body kits, body work in general, and all types of exterior modifications. |
04-16-2006, 07:35 PM | #1 | |
Primer Problem
This is the first time Ive painted a car with pro paint and Iam having problems with the primer. I painted the primer on with my gravity feed spray gun and when i was done i took of the cap to clean it out with paint thinner and after i put all the thinner thru the gun it didnt work. A thin layer of primer was left on the walls for the cup and little chunks of it were sitting at the bottom of the cup, thankfully the gun has a filter. I had u clean it with the Urethane Activator. I used Nason 421-19 2K Urethane Primer and mixed it with the 483-87 Activator, in a room around 70 degrees. Could it of been that i didnt put enough of the activator in it or to much? Thanks
04-16-2006, 07:49 PM | #2 | |
Re: Primer Problem
you should ask in the "detailing" section
sorry, i couldn't be of more help |
04-20-2006, 09:01 AM | #3 | |
Re: Primer Problem
i had that happen the first time i tried to use this wierd type of primer called epoxy... it was because i had never painted a car before, so i tried to mix the paint in the cup on the gun lol!!! it turned all globby and stuff and it took over an hour to clean out the gun
