| Latest | 0 Rplys |
03-14-2006, 03:54 PM | #1 | |
checking codes on a 95 grand am?? And other issues.
Hello I just purchased a 1995 grand am 3.1 with 148500 miles.
The check engine light came on and I wanted to retrieve the code/s. However the obd-1 connector lacks a "B" pin. So I can't use the paper clip trick. Is there anyway to check the codes without a scanner? Autozone said they couldn't do it. They could only handle obd-2. On a side note the car seems to be leaking oil from every gasket and all but 2 plugs had heavy carbon deposits. Do these cars have problems with valve seals or could it be an intake gasket leak? |
03-14-2006, 06:37 PM | #2 | |
A990 racer
Re: checking codes on a 95 grand am?? And other issues.
You need a "real" scanner to check codes on a 95, the engine should be cleaned up and then checked for the exact source of the leaks.
03-14-2006, 06:48 PM | #3 | |
Thats what I figured. Thanks for the reply.
I'm not looking forward too hunting down all the leaks. Changing any of the gaskets looks like a real nightmare on this car. I've never seen more hoses, wires, and sensors in one compartment. I used to be a Ford Tech so th GM world is new to me. I'm not trying to start a GM vs. Ford thing either. Checking online I see a couple of different versions of intake gasket sets. One with pushrod guides in the gasket the other without. Any way to tell what you have before pulling the intake? I hate stopping in the middle of a job for a parts run. |
