Old 01-10-2006, 07:11 AM   #1
klutz_100
klutz_100's Avatar
Can this be saved? Please?
What to do?
Tamiya 2CV. Primed with Motip grey auto plastic primer (used a few times before without problems). Painted from rattle can with Motip Gloss Black acrylic auto lacquer. 2 mist coats. Lightly wet sanded with 2000 grit. One wet-ish coat and then on the second wet coat it dried out into this! look at the front fenders...
Can this be saved do you think? Or will it need stripping? 6 months work and I was getting close
Also, what happened? I was painting in my cellar workshop, ambient temp around 10-14 centigrade. Lots of snow and frost outside.
Your help/advice MUCH appreciated.
Old 01-10-2006, 07:32 AM   #2
bri g
Re: Can this be saved? Please?
looks like the top coat ate through the primer and etched the plastic. I've had that happen to me before and if the etching is not too deep, just strip the paint in brake fluid and then give it a good sand to even things out.
bri g is offline   Reply With Quote
Old 01-10-2006, 07:36 AM   #3
primera man
"P-Man"
primera man's Avatar
Strip it and start again.
How long did you wait utill you painted before you wet sanded?
Looks like it may have trapped some water between coats or the paint has attacked the primer
View All My Models Here.
primera man is offline   Reply With Quote
Old 01-10-2006, 07:56 AM   #4
INsejn
INsejn's Avatar
Motip gloss black is weird paint. It can leave very rough orange peel. Try to sand this with 2000 grit and maybe it`ll help. I had problems with this paint too but i sanded it and was ok.
INsejn is offline   Reply With Quote
Old 01-10-2006, 08:39 AM   #5
ZoomZoomMX-5
ZoomZoomMX-5's Avatar
Don't strip it yet! That can probably be fixed, I've seen much worse. First you should see if you can sand it smooth. Perhaps a clearcoat (Tamiya or enamel or acrylic like Gunze Mr. Topcote-don't use more automotive stuff) can then be applied to gloss it up w/o lifting the paint. Or use Tamiya black instead of automotive paint. Don't strip it unless those two tricks damage or further damage the paint underneath.
Too many modelers freak out and automatically strip paint that can be much easier fixed than all the time it takes to strip and start over. At least try to fix this...it will likely save you a lot of further trouble.
My Fotki Album
ZoomZoomMX-5 is offline   Reply With Quote
Old 01-10-2006, 09:18 AM   #6
bigfrit
bigfrit's Avatar
Hey, stevenski!
consider myself an expert in fucking up paintjobs
This looks pretty bad tho, i had a similar experience with the gloss black by motip.
Once it went on pretty well, dried up neatly, then I let it rest quite a long while and decided it could use an extra coat of paint (not clear) so I painted it.
Three weeks after this i took the car from the drying place, and checked for any irregularities; and pow, the paint just peeled off!
quite funny.
And another time, i had similar results (if you want to call em that) as you have now, i decided i was going to put it in the DOT4 as it's quite thick, the motip paint.
I guess it's all up to you, you can try and fix it, but beware of the panellines!
oh, and now I m only using tamiya paints, and still manage to fuck up!
Oli
Old 01-10-2006, 11:38 AM   #7
klutz_100
klutz_100's Avatar
Re: Re: Can this be saved? Please?
Originally Posted by bigfrit
Hey, stevenski!
So Oli, in your expert opinion, this paint job is definately f**ed up then, huh?
Thanks gents for the input.
I've decided I'm going to go for a "save" (for the practice and the learning curve) and since the project is supposed to be weathered anyway. If that still doesn't work out acceptably, then I can still strip it anyway. Interesting to see what happens...
Old 01-11-2006, 06:59 AM   #8
klutz_100
klutz_100's Avatar
UPDATE:
Methinks things are looking optimistic at this point!!
I did a test on just one wing (fender?).
First I fairly gently wet sanded it with 1200 grit.
Then I started smoothing out with 2000 and 2500 grits. I followed this up with macguire's scratch-X (first time using it and think it's tons better than taiya corse compaound) and then macguires cleaning wax.
Here you can see the treated and untreated parts:
And here's a close up of the treated part:
There are still some very fine marks in there but I think that actually this is a finish close to what I would call realistic on a used car which is what i am aiming for BTW.
It's very difficult sanding carefully in some of the creases and I barely rubbed through to primer on a couple of edges but if this is the worst I do, I'll will turn that into weathering.
I'll try this technique out on the rest of the car. If it works, it's good testimony to what can be achieved with some sanding and rubbing!
Old 01-11-2006, 07:16 AM   #9
ZoomZoomMX-5
Now wasn't that a lot easier than stripping the paint and starting from scratch? This thread needs to be seen by everyone who automatically says "strip it!" when they get a paint problem. Unless it's a grievous error or the paint is getting too thick, stripping should be saved as the last resort; if you keep calm and keep cool you can often fix a problem like this. Great save!
My Fotki Album
Old 01-11-2006, 07:45 AM   #10
bigfrit
bigfrit's Avatar
have to agree with ZZ MX5, awesome save there!
Oli
Old 01-11-2006, 08:25 AM   #11
klutz_100
klutz_100's Avatar
Thanks ZoomZoom! Good call and good advice.
Oli, there are still another 3 fenders and a few body panels left for me to f-up
Old 01-11-2006, 08:26 AM   #12
Vric
Vric's Avatar
This look better. Black is very hard to get a good finish (well this is the color that give me the most problem and never end up with great result) anyway, some more polishing and it could be good !
Vric is offline   Reply With Quote
Old 01-11-2006, 08:38 AM   #13
gionc
Authorized Vendor
gionc's Avatar
Looks great, I was too much in a hurry, so I'm really happy for you
gio
