| Latest | 0 Rplys |
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems. |
12-21-2005, 04:24 PM | #1 | |
Air to Liquid Intercoolers
Hey, what exactly are air to Liquid intercoolers, what components are involved in making them work, and do they need a constant air supply to work like a air to air intercooler? Also how come the Bugatti Veyron uses air to liquid intercoolers instead of air to air intercoolers? I thought air to air was better for street use
12-21-2005, 05:53 PM | #2 | |
AF Ford Contour-Advisor
water to air intercoolers is pretty much exactly what it sounds like, however instead of air cooling the air, water cools the air. It sorta works a little bit backwards though from an air/air setup. In an air to air setup, the compressed air flows through passageways (im not sure of the technical name for them) while the outside air passes through the gills of the intercooler to help cool the passageways. However, for a water/air intercooler the compressed air is passing through the gills of the intercooler while the water is passing through the passageways.
To make this work, you obviously need an intercooler core and then need to weld up some enclosure for the core so the air cant escape as it goes into the engine. Usually a water resevoir is mounted in the trunk for the intercooler, so piping has to be routed to the intercooler and then back to the resevoir. A pump is also needed to circulate the water. Its also good to have a heat exchanger to help cool the water after its passed through the intercooler since air temps can become pretty high. Both are good for street use. Water/air intercoolers are more efficient than air/air but the downside is the water does heat up fairly quickly which reduces effiecieny. Also for some cars, like my car (Ford Contour), packaging is an issue and plumbing a large enough front mount intercooler thats sufficient just isnt feasable, so a water/air intercooler under the hood was required. Heres a picture of my water/air intercooler.
"The CEG Nazi" www.contour.org 1996 Ford Contour SE - Sold 3.0L V6 and Arizona Dyno Chip Turbo Kit 364 whp, 410 wtq @ 16 psi and only 4,700 rpms. 1999 Tropic Green SVT Contour - Bone stock and MINT |
12-21-2005, 07:06 PM | #3 | |
Air to water intercoolers are really good for like a minuite use, (water is 14 times more effective than air at removing heat from aluminum) after that the chilled water heats up and now you have hot air and hot water. They are used on dragsters alot for their short but effective lifespan. Air to air intercoolers can cool effectivly as long as you want to run them. An intresting mix of the two properties is an air to air intercooler that sprays a fine mist of water onto the heat exchanger eveporating to water cooloing the air even more, works like a charm.
12-21-2005, 08:08 PM | #4 | ||
Re: Air to Liquid Intercoolers
12-21-2005, 11:21 PM | #5 | ||
Using my car as an example: The now heated water from the intercooler is pumped many feet forward to a large radiator near the front of the car that is located in a rather spiffy duct. This intercooler radiator is in front of all the other radiators so it gets first crack at the cold air. It is VERY important to get rid of as much heat as possible from the radiator at the front of the car so the engine can make max. power in a sustained situation (like going to Taco Bell). Since the plumbing is very long, it takes about 30 seconds for the coolant fluid (antifreeze) to make a complete cycle, so you don't need a reservoir. For all this goodness there is a downside, in my cars case-- the factory claims only 69% total system efficiency in 100*F ambient air, sustained, which is lower than a good air-to-air system. |
12-22-2005, 12:50 AM | #6 | ||
Re: Re: Air to Liquid Intercoolers
12-22-2005, 06:29 AM | #7 | |
well i think that we should acknowledge THREE types of intercoolers here. Air to air, air to liquid, and air to liquid to air. Air to air is self explanitory. Air to water is pretty simple. It is basically an air to air intercooler that has pretty much had a tank welded around it that can be filled with ice cold water for short term efficiency. Now the Air to liquid to air (as i am calling it) is just like the air to liquid setup except that the tank now has a water inlet and outlet and a pump to take water away from the intercooler and to a heat exchanger that is in the airflow of the car. I BELIEVE that this is the same setup as the EB 16.4 (Veyron). See those two big scoops over the engine? They are cooling the intercooler's heat exchangers. This is a common setup in mid engined cars because it is eisier to run a water line to the front of the car than a charge air line. As black lotus said.
Cars are like music. If it ain't fast it ain't shit. |
12-22-2005, 10:55 AM | #8 | |
I've heard of some people hooking up their water intercoolers to their engine cooling assembly (like the radiator and such) i don't know how effective this is, it seems to me that the engine cooling gets pretty hot but it can keep its efficiency over a long time.
To me the air-water-air seems the most effective for a cramped space, if you don't have room to get your intake plumbing to a cool place for an intercooler, install this. also all the extra intake plumbing adds turbo lag because the turbo needs to pressurise all that tubing before it gets to the engine. with an ai-water-air system you can keep the intake plumbing as short as posible and still have effective cooling. An air-air setup seems the easiest to install with good efficiency, you don't need to hook up your intercooler, water plumbing, and heat exchanger, as well as find room for all of it. for street use it seems pretty good. The subaru imprezza, don't know what year, used a button to spray water onto the intercooler, it was just like a winshield washer thing but pointed inside the egnine at the intercooler. i don't know how effective this was at cooling the air, and it doesn't last long, but it seems good for some emergency cooling. |
12-22-2005, 02:36 PM | #9 | |
oo so lets say you have a mid engined car at around 800 hp. What kind of intercooler would be the best choice given that you dont have a constant air flow to the intercoolers?
12-22-2005, 03:28 PM | #10 | ||
I know this post will get some flack so I'll try to explain as best I can-- Assume compressor output as 400*F (pressure ratio is 4+) and air temp as 80*F. If the radiator eff. is 80%, then the engine will then be ingesting 144*F air. Now, if you run it thru engine coolant cooled radiators first, then air-to-airs (like they did), it works out to-- 400*F output into the first stage (engine coolant intercoolers) running engine coolant temps of~180*F you get about 224*F output. Now run that 224*F thru the air-to-airs (ambient air at 80*F) and you get 109*F air into the engine. I approximated all these numbers (pulled them out of my a$$), but you should get the picture. |
12-23-2005, 05:44 AM | #11 | |
yea it does kinda make sense if you follow it.so yea what type of intercoolers would be best for a 800 hp midengined car given that there is no constant airflow to the intercoolers??
12-23-2005, 06:37 AM | #12 | |
well there are some mid engined cars like the turbo mr2 and some porsches(ok rear engine) that had air to air mounted in side ducts. The new bugatti veyron uses air to water to air and that is 1k hp. i think you will not find many race cars that use air to water. i think most (like LeMans prototypes) use air to air. I would preffer to use air to air cause of the weight savings and simplicity.
12-23-2005, 01:27 PM | #13 | ||
For reasons given above. |
12-23-2005, 02:37 PM | #14 | |
air to water to air?? so those intercoolers dont need fresh air flowing through them to work right?? because say I have a midengined car that needs intercooling but i don't want to ruin the design with vents and scoops. air to water to air would be best??
12-23-2005, 11:36 PM | #15 | |
AF -Advisor
air-to-air is the most common because they are simple and don't require water and a water cooler....the water-air intercoolers work very well until the water heats up, then you're kinda F'ed.....but like was said above, packaging can be an issue and the water-air can be fitted into a small area that doesn't have air passing across it....
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR |
