Go Back   Automotive Forums .com Car Chat > Chevrolet > Lumina
Old 10-25-2005, 04:26 PM   #1
Blackattack
Question 92 3.4 5 speed high idle NEED HELP FAST
I have a 92 z34 3.4 5 speed that idels at about 3000 rpm for a while then all of a sudden it will idle up and down. for example it will go up to 3000+ then drop rapidly to 700 rpm and then keep doing it till it decides to stop then it may run fine for little while then do it all over again.it mainly idles 3000+ upon startup.i changed (TPS) and (IAC) dont know what else it could be please if you have any answers im all ears..THANK YOU..
Blackattack is offline   Reply With Quote
Old 10-25-2005, 06:11 PM   #2
maxwedge
A990 racer
Re: 92 3.4 5 speed high idle NEED HELP FAST
LOOK AROUND FOR VACUUM LEAKS, AROUND THE PCV SYSTEM, THRoTTLE BODY, ANY VACUUM HOSE/FIttING, ESPECALLY LARGE ONES, USE CARB CLEANER AROUND THE TB, TO CHECK FOR A LEAK AT THE BASE. CExcuse caps, don't want to retype!)
maxwedge is online now   Reply With Quote
Old 10-25-2005, 06:29 PM   #3
Schurkey
And then start suspecting bad intake gaskets.
For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China.
Schurkey is offline   Reply With Quote
Old 10-26-2005, 05:03 PM   #4
alto
lumina 3.1 knoking on the motor, how to adjust the balances?
alto is offline   Reply With Quote
Old 10-26-2005, 05:07 PM   #5
alto
Lumina 3.1 the motor is knocking I know the valves are hydraulic, I think the balances need adjustment, can you help me.? Thank you.
Old 10-26-2005, 05:11 PM   #6
alto
I need to know how to adjust the balances from the valves, it is making noises, can you help me?
Old 10-26-2005, 06:34 PM   #7
maxwedge
A990 racer
alto, balances???? Try and clarify what you mean, there are no valve/rocker adjustments on the 3.1, though.
Old 10-28-2005, 02:09 PM   #8
Corkscrew
alto:
1. Don't ask a different question in another thread. Start a new one.
2. Don't make three posts in a row, especially within 4 minutes of each other. Give people time to reply.
3. Spell checker is your friend.
Same with here
http://www.automotiveforums.com/vbul....php?p=3526008
Corkscrew is offline   Reply With Quote
Old 10-28-2005, 10:06 PM   #9
richtazz
stupidity should hurt
richtazz's Avatar
Ouch Corkscrew, a little harsh, but a good point.
richtazz is offline   Reply With Quote
