| Latest | 0 Rplys |
#1 | |
![]() Join Date: Nov 2004
Universal door lock Actuator will work on 2001
:ebay Item number. 5795165295 Universal power door lock Actuators..
I DID SOME RESEARCH A WHILE BACK ON THE POWER DOOR LOCK ACTUATORS. In some cases the front door locks would not work half the time or not at all. in my case the pasanger side stop working all together.. The door lock actuactor was too pricey and would most likely go out again.. The universal type is a cheap replacement that works really well. Location is the key and is not hard to do..I did mine in about 2 hours but would have been done sooner if I did not have to scout my location and plan my action. On the pasanger side the wires are easy to get to I spliced right in leaving the old actuator in place and still pluged in.. There is a square hole in the area along with a big opening and a small hole. the small square is were I put the actuator.. The wires that control it are red and light blue from the winstar.. I will try to take pics later, but I just wanted to say it will work.. my next project is the drivers side.. It works half the time, and will again leave every thing in place just add the uni actuator... Keep in mind clearance issues with the window if you have it high enough and close too the inside wall were you can see it through the square hole you will have no trouble.. The Ebay item number I have shown is for 4 actuators but I just put that there to show what type I used...You can get what you need,, one is about 8.00 with shipping if your a lucky bidder... Hope this helps try to have pics soon.. Gary ![]() |
#2 | |
Re: Universal door lock Actuator will work on 2001
Good job. My driver's side doesn't like to lock (but will unlock, wierd). I might go this route.
#3 | ||
Re: Re: Universal door lock Actuator will work on 2001
#4 | |
![]() Join Date: Oct 2003
Re: Re: Re: Universal door lock Actuator will work on 2001
Look forward to the pics. When you say you left everything hooked up as is, did you leave the original actuator still hooked up to the lock rod? When I replaced my actuator recently it had a lot of drag from age and built up grime. I would think that might affect the life of the new universal actuator if it has to move the old actuator assembly as well as the lock. Might be worthwhile to leave it in place but disconnect where it attaches to the lock rod.
Then again if its only $9 you could buy a bunch of replacements and not worry about it.
1997 Pathfinder XE Air Lift Air Bags, Warn Hubs 2000 Windstar SEL |
#5 | |
got the pics need to know were to post them. Pics wont download here.
As for the auto lock feature I will explain that I need to further study this.. |
#6 | |
You can post them here:
http://groups.msn.com/FordWindstar Then add links in a post here to the photo pages.
#7 | |
Got to that site, signed up but cant find were to upload pics ..easy on this site but my pic size are 1mb or more. I can email if some one pm's me.. Also u think i could downsize my photo but not to sure how or if it can be done. I guess I will do more thinking... LETS GET R done..
#8 | |
If you download Picasa from Google (free) it will resize your pictures for you for emailing. It is a great program for handling digital pictures and the price is right :-) Tim
#9 | |
http://windstarlock.blogspot.com
This is the site where I posted the pics and gives some info.. I have more pics that lewis form this forum is helping me with. I hope these work and will try to add more once i get it all figured out.. Gary http://doorlock2.blogspot.com Last edited by garync1; 08-14-2005 at 10:32 AM. |
#10 | |
Btt
#11 | |
I just wanted to post that for 7 months now I have not had any problems with the universal actuators I added on after the windstars front door locks failed. I still think this is an easy less expensive way to fix the power door lock problems.Hope this helps..
#12 | ||
![]() Join Date: Apr 2006
I am planning on replacing the actuators in the front doors, and I was very glad to see your post. Autozone wants $45 for each actuator and I need 2 meaning a total of $90 which isn’t horrible, but if I can do it for $15 that is obviously much better :-D. I was reading through some of your posts on this topic and it wasn’t clear to me why you left the old actuator in place. Would you mind explaining this? Thanks, Chris |
#13 | |
Hi Gary - awesome post and pictures -- thanks very much for taking the time and effort.
On my 2000 Windstar three out of the 5 locks (two front and right rear slider) are either on their way out (and getting worse week by week) or not working more than a slight quiver. I was getting a little anxious at the price to fix all these actuators until I came across your post. I found what looks like a very similar actuator on ebay but wanted to run it by you anyways: Ebay#: 9708714808 Like the previous poster I would also like to know the reason for keeping the old actuator connected physically and electrically. And on the following picture on your blog it appears as if the mount strip has been bent somewhere behind the sheet metal. Was that required or is it just an optical illusion?? thanks again Ian. |
#14 | ||
#15 | ||
