Old 07-31-2005, 01:16 PM   #1
Eric Cole
Eric Cole's Avatar
"How-to: Fiberglass"
“How-to, Simulate Fiberglass in Scale”
While working on the 1/12th scale Tamiya Porsche 935 Turbo I thought the parts in the kit would lend themselves well to an actual fiberglass pattern or effect. After several tests, this is the method that I came up with which seems to best replicate the “scale-look” of fiberglass.
In this first picture you can see the tools and materials needed for this process. The cloth I used is just a simple sheer cloth picked up from any fabric store. It’s the type that would be used for making curtains or something similar. You’ll need liquid cement for plastic, scissors, an x-acto knife and toothpick or other tool for pressing the cloth into the crevices of the plastic part.
Here, you can see that I’ve cut a hole in the cloth for the mounting pin of the kit part to protrude through and then simply draped the cloth over the part. Keep the mounting pins and holes of parts as clean as possible to avoid difficulties attaching the parts during your assembly.
Choose your starting point, pull the cloth back and apply a layer of liquid cement to the kit part. Apply a generous amount of cement and give it a minute to soften the plastic. The brand of cement and the amount applied will determine your wait time for the plastic to soften. What you want to achieve is enough softening for the cloth to actually press into the softened plastic without the plastic really oozing through the cloth.
Pull the cloth back over the softened plastic and begin pressing and working the cloth into the plastic with a toothpick. You may have to work with it for a few minutes until the plastic starts to set-up or harden again to ensure the cloth doesn’t pull away as you move to the next section.
After the plastic has begun to set-up and harden, paint a thin layer of plastic cement over the cloth. This process just seals the cloth to the plastic and smoothes out the texture a little bit.
Here’s the result of the process to this point.
Continue the above steps working your way around the part. Work in sections as you soften the plastic with the liquid cement and pressing the cloth into the plastic.
Inevitably, just like working with a flat decal on a curved surface, you may have to make small cuts in the cloth to get it to conform to the part. Just apply a little more cement and keep working it in until the cloth stays where you want it. Keep in mind, real fiberglass is worked in sheets and cut where necessary also.
A little more cutting and one side is almost complete.
After the cut mentioned above and working the cloth around the corner.
One side completed. Just repeat this process of applying the liquid cement in small sections to soften the plastic, press and work the cloth into the softened plastic making cuts in the cloth where necessary to make it conform then apply a thin layer of cement on the cloth to even out the texture and seal the cloth to the plastic.
Here’s the completed part with a wash of Tamiya X-19 smoke, X-22 clear and some dirty acrylic brush cleaner as the thinner. I washed the parts with this mixture to get the effect you see here. You can mix your wash to get the effect you desire from very clean new fiberglass to very dirty used fiberglass.
As a note: this particular kit part was molded in a translucent tan color which helps with the overall look. Parts molded in other colors will have to have a light coat of primer (I recommend tamiya Fine White primer as it won’t cover up the texture you’ve worked hard to achieve) then apply a wash of Tamiya XF-59 Desert Yellow or XF-60 Dark Yellow directly to the white primer to get the basic tan color. After that wash has dried thoroughly you can then apply your “dirty” wash for the final effect.
Hopefully, some of you will find this helpful to achieve that extra texture and detail we all strive for while trying to duplicate realism in our scale models.
Thanks for looking……..
Eric Cole
Other Model Pictures Here:
http://s5.photobucket.com/albums/y197/justdande/
Eric Cole is offline   Reply With Quote
Old 07-31-2005, 01:22 PM   #2
Honoturtle
Great how to. I wonder how well it'll work with 1:24 parts.
AF MODELING FAQ
"Oh what a feeling.- Toyota
Honoturtle is offline   Reply With Quote
Old 07-31-2005, 01:23 PM   #3
mike@af
Captain Over Engineer
mike@af's Avatar
Re: "How-to: Fiberglass"
Awesome tutorial Eric. It was even better watching it in person. Great work. Are you sure that sheer isnt Deanna's?
-Mike
mike.lawrence@automotiveforums.com | AutomotiveForums.com | Flickr Gallery
mike@af is offline   Reply With Quote
Old 07-31-2005, 01:29 PM   #4
Sticky Fingers
Sticky Fingers's Avatar
Superb how-to and great pics. I spose you for 1/24 scale you just need cloth which has a tighter mesh.
Sticky Fingers is offline   Reply With Quote
Old 07-31-2005, 01:41 PM   #5
Veyron
Veyron's Avatar
Awesome!
Veyron is offline   Reply With Quote
Old 07-31-2005, 01:57 PM   #6
klutz_100
klutz_100's Avatar
Great tutorial - from idea through to presentation!
Thanks for sharing
Old 07-31-2005, 02:29 PM   #7
blubaja
blubaja's Avatar
WoW!!! That's a great tip!! Gotta try it!
blubaja is offline   Reply With Quote
Old 07-31-2005, 02:43 PM   #8
lazbun
Thanks for the tutorial Eric, very well present.
I suppose the procedure will be the same if I use fabric softener paper ?
lazbun is offline   Reply With Quote
Old 07-31-2005, 04:29 PM   #9
robrex
robrex's Avatar
Thanks for the tip Eric!
Rob
robrex is offline   Reply With Quote
Old 07-31-2005, 04:45 PM   #10
Eric Cole
Eric Cole's Avatar
Re: Re:
Thanks all.....
Yes, infact I have used fabric softening sheets the same way, It actually conforms to curves better than regular fabric. It just gives you a less uniform pattern because of the randomness of the fibers.
Eric Cole
Old 07-31-2005, 09:03 PM   #11
p9o1r1sche
Registered User
p9o1r1sche's Avatar
Thanks for the tutorial, Eric. I'll be using this technique soon.
p9o1r1sche is offline   Reply With Quote
Old 08-03-2005, 07:04 AM   #12
bvia
bvia's Avatar
I've used camera lense cleaning cloths to achieve the same effect (on the interior cockpit of my Fujimi 917), but remember that the cloths and the fabric sheets are perfect for the "chopped matt" construction of blown-in fiberglass whereas the above sheer fabric method is perfect for woven fiberglass construction!
Great job, great tutorial and thanks for taking the time to show it to us!
Bill
Bill
"Why yes, that IS my bare, carbon fiber Enzo in Scale Motorsport's "How to Carbon Fiber Decaling video!"
bvia is offline   Reply With Quote
Old 08-03-2005, 08:26 AM   #13
Hiroboy
www.hiroboy.com vendor
Hiroboy's Avatar
Nice "How To" Thanks
Steve a.k.a. Hiroboy
Hiroboy is offline   Reply With Quote
Old 08-03-2005, 08:36 AM   #14
willimo
Sweet, sweet tiny Hondas.
Great idea! Thanks for sharing.
Old 08-03-2005, 02:29 PM   #15
Murray Kish
Getting Old...
Awesome. Saw the other pieces in your build-up and have been hoping you'd do a how-to.
Thanks.
Murray
Murray Kish is offline   Reply With Quote
