| Latest | 0 Rplys |
07-27-2005, 11:39 PM | #1 | |
1995 LeSabre A/C Recharge questions
1995 LeSabre with 50k miles & A/C is not cold enough.
Picked a recharge kit & gauge and the gauge said the system was overfilled. Did I hook the gauge up to the high side by mistake? I thought the high side had a bigger nozzle than the low. What is the proper PSI for the a/c system? Where is the refill nozzle located? Thanks! bipra |
07-27-2005, 11:57 PM | #2 | |
AF Moderator Elite
Re: 1995 LeSabre A/C Recharge questions
High and low side has different size fittings. The low side is the smaller fitting and where you charge the system, also the only one that the charge kit will fit. Normal R134a systems operate at 30-45 psi on the low side @ 75 to 85 ambient temp. Be sure your engine is running for 3-min (to stabilize system) with air conditioner on high, then start your charge.
07-28-2005, 10:50 AM | #3 | |
Re: Re: 1995 LeSabre A/C Recharge questions
Thanks for the quick reply.
It appears the that the low-side was overcharged... however, the compressor clicks on and off intermittently every 5 seconds or so. I have read on these forums that this could be an indication of low charge. When I checked it initially the gauge pointed to "ALERT", so I discharged until it was in the green. It now reads fully charged, but the a/c is now poorer than before. Should I charge it regardless of this gauge reading or will I damage the system? Thanks, Bipra |
07-28-2005, 12:37 PM | #4 | |
unhook battery cable to let system clear itself and start over, let cables unhooked for about 30 seconds. this may reset the system, as it was previously overcharged a high pressure reading was read and the hig/low switch was tripping the compressor to prevent damage. post back with details.
07-28-2005, 03:34 PM | #5 | |
AF Moderator Elite
If your compressor is cycling with a full charge and not cooling, then your compressor is weak, and not pumping the Freon at the pressure required to cool!! Install a new compressor. Again, low side should be 30-45 and high side 220-280 with the ambient mentioned above
07-30-2005, 05:13 AM | #6 | |
HotZ28?
My a/c system has leaked down some, enough to blow ambient air. When I connect to the low side, do I hold the first can upside down or right side up? I have heard it both ways. |
07-30-2005, 09:45 AM | #7 | |
I disconnected & reconnected battery, and nothing changed..
07-30-2005, 10:05 AM | #8 | ||
AF Moderator Elite
Re: Re: Re: 1995 LeSabre A/C Recharge questions
07-30-2005, 10:24 AM | #9 | ||
AF Moderator Elite
07-30-2005, 12:03 PM | #10 | |
Main GM Guy
Try not looking at the color code of the guage. This guage is made for a generic system. I wouldn't go by the color codes.
What you want to see is numbers like HotZ28 posted. Another thing to look at with the engine shut off your low pressure should be slightly above ambient temp.
Shop Foreman Buick Pontiac and GMC dealership ASE Master Tech ASE Advanced L1 GM Master tech Licensed Aviation mechanic |
07-30-2005, 02:12 PM | #11 | |
I bought the Wal Mart freon can and gauge package. $26.50 Was nervous at first with the high pressure reading but the compressor finally stayed on, the pressure lowered, and charged to about 40 pounds. I did the hot water soak also.
The cheap gauge set I got in the package, about 8" long, has the gauge in the middle of the line. The gauge has a check valve, not allowing you to purge the line completely. I possibly got a small amount of air in the line when I hooked up the quick disconnect, not sure. Am I in trouble here? thanks |
07-30-2005, 10:55 PM | #12 | |
AF Moderator Elite
If you got the low side down to 40 psi, and the compressor is running without cycling too often, you should be OK. Is it cooling? If it is, drive it around for awhile and recheck the low side before turning off the engine. If it is still at 40 psi, see if you can add enough Freon to get it in the 35-38 range. If it is cold enough, don’t worry about it.
07-31-2005, 01:00 AM | #13 | ||
Thank you for the info |
