Go Back   Automotive Forums .com Car Chat > Chevrolet > Cavalier
Old 07-12-2005, 10:58 PM   #1
skeavs
Removing door panel
Where would i get one of those GM tools to take off the door panel in a manual window 99 Z24? Thanks in advance
skeavs is offline   Reply With Quote
Old 07-12-2005, 11:32 PM   #2
PsychoJJ
PsychoJJ's Avatar
Send a message via AIM to PsychoJJ
Re: Removing door panel
Pepboys, autozone, checker. Pretty much most big name auto companys or you can go to a dealership and get one but Im sure they will rape you on the cost.
Even pure genius is born out of insanity!
Big thanks to Lance for the sig pic.
PsychoJJ is offline   Reply With Quote
Old 07-12-2005, 11:45 PM   #3
skeavs
Is there anything else i could use as an replacement. I just want the door panel of to replace speakers.
Old 07-13-2005, 12:53 AM   #4
Thor06
Jizzed In My Pants
Thor06's Avatar
This is funny... I took mine off a few time to replace speakers and what not. I lost my crank and just bought a new one today. I was walking around the junk yard with the worker and he had one of those tools. He said it was "only a few bucks." How much that means, I dont know, but I think that tool is worth it. To get the crank off the first few times I used a screw driver. Yeah, it worked, but the tool is much faster/ easier and you dont run the risk of gnarling up your door panel. If you dont want to buy the tool, I would also think that if you went to any shop they would take off your cranks for free.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Thor06 is offline   Reply With Quote
Old 07-15-2005, 06:24 PM   #5
skeavs
does anyone know what they are called so i can ask for it by name?
Old 07-15-2005, 06:45 PM   #6
jayson716
so much easier to have power lol...
-Jay Jones
Team DROPZONE
Vice President
jayson716 is offline   Reply With Quote
Old 07-15-2005, 11:48 PM   #7
Thor06
Jizzed In My Pants
Thor06's Avatar
I would just call it a window crank removal tool... if thats not what its called they will know what you are talking about.
Old 07-16-2005, 12:03 AM   #8
PsychoJJ
PsychoJJ's Avatar
Yeah, thats pretty much what they call it but at most places you need to add in GM into the window crank removal tool. Last time I picked you up from pepboys it took 3 people to figure it out then I said GM and they looked like I just came up with the meaning of life for them.
Old 07-16-2005, 05:36 PM   #9
skeavs
I went and bought the tool, but in the instructions it says, inset tool then remove the clip. I dont have a clip and it still wont come off. Any ideas anyone?
Old 07-18-2005, 09:57 PM   #10
skeavs
Bump
Old 07-18-2005, 11:18 PM   #11
deadBird
deadBird's Avatar
It's almost impossible to see, but it's there... unless of course it somehow came off. If that's the case brake it off. I suggest getting one of those dentist type mirrors to see if you can find exactly where it is.
deadBird is offline   Reply With Quote
Old 07-18-2005, 11:30 PM   #12
PsychoJJ
PsychoJJ's Avatar
Oh the things I do for you people. Ok using this handy microsoft paint mock up of the clip I have made We will see the best way to do this thang.
The two prongs with the green arrows pointing to them should be facing the same direction of the crank you grab ahold of to roll the window down. The area with the red arrow should be facing the side that is rounded on the crank. If you have a dental pick type animal slip it in behind the crank via the rounded off side and twist the pick so that it grabs ahold of the area that sticks away from the crank with the red arrow on it. PULL! It may take a few trys but it will go.
Old 07-25-2005, 11:47 PM   #13
skeavs
I keep trying and cant find any clips what so ever, none at all. I keep pulling and yanking on this crank and not a dam thing will come loose. What do i gotta do i got these speakers sitting there that i want to install.
Old 07-27-2005, 01:13 PM   #14
4dr92cavi4cyl
4dr92cavi4cyl's Avatar
Nice illustration Psycho, ms paint, LOL!
If it's not comming off then there IS a clip there, between the panel and the crank. It's maybe as thick as a penny so it's not easy to see. Like Psycho said, the open end of the clip is lined up with the crank, so try using the tool parallel to the crank. KEEP TRYING! Once you figure out how to get one off the others will be easy using the tool.
Odometer: 223259 & still running like a horse!
Rockin' to: Dream Theater, Queensryche, Symphony X, and Pagan's Mind. Check them out!
The "radio groups" these days have lost creativity and skill. It's the same thing for five minutes.
4dr92cavi4cyl is offline   Reply With Quote
Old 07-28-2005, 12:06 PM   #15
cavzilla_z24
cavzilla_z24's Avatar
you could always slide some rope down in the door panel and tie it off to say a freinds SUV get about 20-30 ft. of slack in the line and tell ur freind to gun it....somthing will give. i promise.
cavzilla_z24 is offline   Reply With Quote
