| Latest | 0 Rplys |
#1 | |
![]() Join Date: Jan 2005
Hello folks,
My '99 Intrigue started giving me problem two days ago. When I went into the work, I had no problem. But started when I left work. I drove about 10 miles/30 mins and it started... When the tranny shifts up, its a sluggish. When I come to a stop... its shifts hard. After 20 miles of this, I was in slowing in traffic, the engine shut off. Also the 'Service Engine Soon' light came on. I pulled into the nearest gas station... checked the tranny oil (it was fine, since I changed it less than 20k ago). And the engine oil was changed two weeks back. Has anyone had this problem or know anything about my it?? Thanks much, -M |
#2 | |
Re: Engine-Tranny Problem??
i had a similar problem, the check engine light came on and this car made a horrible metallic grinding noise sometimes at parkinglot speeds, and it was a little jumpy, the light stayed on for about 4 days..and then it just went off...and the symptoms went away and haven't been back since...although a day later after the light went off the car shut off while accelerating at 30mph, but it didn't stall it was like someone ripped the key outta the ignition i lost all power radio, gauges, etc...dead...pulled over started up fine and we continued on..no problems since...knocks on wood...
#3 | |
bring your car in someplace to get those OBD2 codes read. Some places will OBD2 scan your car for free (ask before you bring it in). Or you can get your own good OBD2 scanner for $100 (Equus etc) or so.
That would be the first thing I would do. Your problem doesn't sound that bad. I would assume it's a tranny problem (the car got to operating temp fine) like the bad or sticky tranny valve. Get those OBD2 codes read and you will have a starting point to work with. Write down your OBD2 error codes and post them here. |
#4 | ||
Re: Re: Engine-Tranny Problem??
Thanks for the infoz. Where can I get a OBD2 reader? -M |
#5 | |
Re: Re: Re: Engine-Tranny Problem??
http://www.amazon.com/
search for OBD or OBDii the Equus for $130-100 is pretty good. But you need to decide if you really want to spend the money, but typically you are charged $50 a hour for auto mechanics now so $100 is cheap. Your engine service lite did go on, so I'm assuming you have some codes being output. Then I would look into getting an AlldataDIY.com account for $25 a year. But people here have them anyway (alldataDIY accounts) and most of the problems are similiar also. Otherwise the service manual set is usually close to $80-$100. You could save your money and go to your local auto parts chain and get the codes read for free. Bring the codes back here and then explain your situation as specific as possible. Harbor Freight has the cheapest OBDii (OBD2) reader I have seen for $40-50, but I would still buy the Equus. You could always borrow out your Equus to friends or charge them to show off your OBD2 code reading ability. My dad has the Equus. If you are into fixing your cars or want to have a better idea of a problem without getting screwed over by a crappy service dealer (at $50+ an hour) I would get an OBD2 code reader. |
#6 | |
Actron has a nice OBD2 scanner as well - ranging from about $50 and up. I bought one at PEP Boys for about $225 and got a cable for older GM cars too, for another 25. As Panzer says, if you're gonna be working on newer cars you should have one. Also, they'll work on any car 1996 and on up!
#7 | |
Yeah, I agree with the above posts about starting with having the code scanned. If you have an AutoZone store in your area they may scan it for you for free, if you don't feel you like spending on a scanner at this time. I'm in Canada and we don't have Autozone in this contry, so I bought a scanner 2 years ago. It really paid itself and a lot more since I have two cars.
#8 | ||
There is a police/taxi version of the 4T65E that is the same price of the regular tranny. This place sells the hardened overdrive sun gear: $17 http://www.transmissioncenter.net/alto_2.htm |
#9 | ||
I got my OBDII today and it read Mass Air Flow low voltage. Does this mean my MAF is F'ed? My dad says this might be it. If the engine has problems with its performance tuning, it will cause problems to the tranny. Sound right? Thoughts? Regards, M |
#10 | ||
Re: Re: Re: Re: Engine-Tranny Problem??
-M |
#11 | |
Re: Re: Re: Re: Re: Engine-Tranny Problem??
Does anyone know what the tool is called to open the MAF sensor?
Its a star with a small point in the center. And where can I get one? -M |
#12 | |
Re: Re: Re: Re: Re: Re: Engine-Tranny Problem??
alldatadiy.com P0102: 2 charts and an electrical schematic also
CIRCUIT DESCRIPTION The Mass Air Flow (MAF) sensor measures the amount of air that is ingested by the engine. Direct measurement of air entering the engine is more accurate than calculating airflow from other sensor inputs. The MAF sensor has an ignition feed, a ground, and a signal circuit. The MAF sensor used on this vehicle is a hot wire type and is used to measure air flow rate. The frequency of the MAF sensor signal is a function of the power required to keep the air flow sensing elements at a fixed temperature above ambient temperature. Air flowing through the sensor cools the sensing elements. The amount of cooling is proportional to the amount of air flow. As air flow increases, a greater amount of current is required to maintain the hot wire at a constant temperature. The MAF sensor converts the changes in current draw to a frequency signal read by the Powertrain Control Module (PCM) . The frequency typically varies from about 2 KHz at idle to about 10 KHz at maximum engine load. The PCM calculates air flow based on this signal. The PCM monitors the MAF sensor signal frequency and can determine if the sensor signal voltage is too low, too high, or not indicating the expected airflow for a given operating condition. CONDITIONS FOR RUNNING THE DTC
CONDITIONS FOR CLEARING THE MIL/DTC
NOTE: Refer to Connector Test Adapter Kit J 35616-A Notice in Service Precautions. A low minimum air rate can cause DTC P0102 to be set during deceleration. Check the minimum air rate as follows:
Numbers below refer to the step numbers on the Diagnostic Table:
