Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 05-09-2005, 06:28 PM
Northern Sun's Avatar
Northern Sun Northern Sun is offline
Send a message via AIM to Northern Sun Send a message via Yahoo to Northern Sun
90' V6 Manifold
i have an oil leak from valve cover that sits underneath intake manifold; I already fix leak from right valve cover and tried to get to left valve cover on the other side, i can't do it, there is this damn bracket welded to bunch of pipes in the front(pretty much next to ignition wires); do i have to cut that bracket off in order to remove intake manifold
Vietcong 3VZ-E
Old 05-09-2005, 07:15 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 90' V6 Manifold
http://www.automotiveforums.com/vbul...d.php?t=405795
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 05-09-2005, 07:17 PM
Brian R.'s Avatar
Resident Chemist
Re: 90' V6 Manifold
http://personal.utulsa.edu/~nathan-buchanan/93fsm/
Old 05-09-2005, 10:22 PM
thanks
Vietcong 3VZ-E
Old 05-09-2005, 10:43 PM
Brian R.'s Avatar
Resident Chemist
Re: 90' V6 Manifold
You're welcome
Old 05-09-2005, 11:05 PM
hmm... i just check 2nd manual pretty much and still don't know how , my 4runner crew doesn't know either
this is what im talking about, that bracket is welded on, moves maybe 2mm up, shietttty picture but ..., whatever
thanks
Vietcong 3VZ-E
Old 05-09-2005, 11:49 PM
Brian R.'s Avatar
Resident Chemist
Re: 90' V6 Manifold
I've got two manuals and no one seems to think it's a problem. Sorry I don't have an engine in front of me. Maybe you are just moving the chamber in the wrong direction. Needs to go sideways ot tilt it a small amount then up or something.
Post a photo?
Old 05-10-2005, 12:38 AM
that bracket is denitively in the way, big time; i could partly lift back of the manifold, front can’t do it. In order to slide manifold out either direction I have lift it up at least few inches; since that bracket doesn't move at all im stack , i'll take few shots tomorrow during the day, thanks for reply Brian
Vietcong 3VZ-E
Old 05-10-2005, 01:13 AM
Brian R.'s Avatar
Resident Chemist
Re: 90' V6 Manifold
If you're in Maryland, I'll stop by tomorrow...
Old 05-10-2005, 01:40 AM
I wish , im in t.o (canada), that's it for today
Vietcong 3VZ-E
Old 05-10-2005, 03:00 PM
here are some pictures:
bracket itself
foto#1
arrows pointing to buch of pipes that won't move at all (max lift 2mm)
foto#2
manifold has to be lift off of that blue bolt in order to be taken out, again, damn bracket is in the way
foto#3
bracket front layout
foto#4
so, that's pretty much the problem im having, suggestions appreciated, thanks
Vietcong 3VZ-E
Old 05-10-2005, 06:53 PM
Brian R.'s Avatar
Resident Chemist
Re: 90' V6 Manifold
OK, that is the bracket I figured you were having trouble with.
If I read the manual right, they say that removing the tubing and hoses from the ends of the steel tubing that is around and under that bracket, and removing the bolt that holds the bracket in place, will allow you to move the bracket enough to remove the manifold.
Brian R.'s Avatar
Resident Chemist
Re: 90' V6 Manifold
If I read the manual right, they say that removing the tubing and hoses from the ends of the steel tubing that is around and under that bracket, and removing the bolt that holds the bracket in place, will allow you to move the bracket enough to remove the manifold. You can bend those tubes a little to gain clearance. I would bend them at the right-angle turn they make to go under the manifold. Bend them as little as possible. You also have a choice as to whether to bend them forward or up and get clearance. Go with whatever direction moves easiest.
Sorry if alot of this is obvious.
Old 05-10-2005, 11:44 PM
Brian R.'s Avatar
Resident Chemist
Re: 90' V6 Manifold
Talk to this guy
http://www.automotiveforums.com/vbul...d.php?t=406737
Old 05-11-2005, 02:11 AM
hmm... interesting , i dont even know where half of these lines are leading to , im not sure if I what a leak on the top of another leak, i think im just better of cuting U legs of that bracket and bending rest off it toward front of the truck (if u know what i mean, look at U legs of that bracket), even thou that bracket has emboss on it i think i might be lucky enough to bend it and slide that manifold sideways. And bending back that bracket later on; if im not mistaken those pipes doesn't even need support; maybe im just talking nonsense here, i dont even know that truck that well yet
Do u think is gonna work ?, Daam 4runners
Vietcong 3VZ-E
