| Latest | 0 Rplys |
Car Modeling Share your passion for car modeling here! Includes sub-forum for "in progress" and "completed" vehicles. |
#1 | |
![]() Join Date: Feb 2005
panel lines
hello,
when painting panel lines, what sort of methods do you use? i am trying to make my panel lines stand out on my current supra but i do not really know how to ![]() does anyone have a easy method that i can do? or should i stick with the efficient el-cheapo method of using a toothpick thanks in advance shinichi |
#2 | |
Re: panel lines
Hey,
Usually, I use flat black paint, thinned. Use a tiny brush to avoid overage. Brush into the panel line. Wipe excess off. Hope it helps. Frank X. |
#3 | |
Re: panel lines
buy a Pigma Micron marker, fit in panel lines perfect.
-Josh- 96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel 98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp. 01' Chevy Blazer, DD. |
#4 | |
Re: panel lines
The most realistic I've seen take the body color and darken it with some black paint...looks a little better then just black.
Check out this tutorial for more info: http://italianhorses.net/Tutorials/Panelines/panels.htm
-Chuck |
#5 | |
"P-Man"
Re: panel lines
Gundam marker pens
Current Build.....1/12 Scale Camaro......Almost finished!!! ![]() ![]() ![]() View All My Models Here. |
#6 | |
![]() Join Date: Jan 2003
Re: panel lines
i just started by using a 10/0 paints brush and warhammer black ink. Its thin allready and it runs into the line so well and is not to dark
glue glue and more glue www.djamos69.com |
#7 | |
I like using Pigma Micron .005 black pens for making panel lines. They're basically a disposable technical pen, I've seen them in most art supply stores and Hobby Lobby/Micheal's. I like to apply the panel lines on an intermediate coat of paint...apply a few color coats, let dry, apply the panel lines w/the Pigma Micron pen, let dry, and apply a few more light color coats. This way the panel lines are ultra-clean, and a darker shade of the color. It's also quite easy to do-less messy than using paint, although the tutorial on italianhorses.net is my second-favorite method of applying panel lines.
![]() An assortment of pigment liners/disposable technical pens that can be used to detail models as well. ![]() .005 is the smallest shown, also shown is .01 and .02 ![]() This picture is huge, the line looks a bit ragged, but you don't see that on the model which is much smaller than the picture.
My Fotki Album |
#8 | |
![]() Join Date: Mar 2004
Never use black. Use the color of the car and darken it just a bit. I find black panel lines ruin the look of a nice build. You are just creating the shadow and if you look close you will see it is just the color of the car only darker. Just my
#9 | |||
Re: Re: panel lines
![]() I agree on White, Yellow, Lime Green and other "light" color, it look bad. But in most case, it make the job done !
![]() CarsModeling.com. My Scale Model Cars blog. |
#10 | ||
Horizontally Opposed
Re: panel lines
![]() I also, ummm... "borrowed" the under-the-paint idea from you Bob. ![]() |
#11 | ||
Re: Re: Re: panel lines
![]() But I have looked at pictures of this car after a race and the panel lines are very dark but are not black. |
#12 | |
Re: panel lines
You are right. It's not 100% realistic, but you can get a good look out of a gundam marker (this is my point)
#13 | |
Re: panel lines
hmmm. id try the darken the body color of the paint but the castrol toms supra is white and if i darkened it, the panel lines would look grey. maybe ill try using a black marker pen or something.
#14 | |
Re: panel lines
At the moment I have Gundam markers but am too scared
#15 | |
Re: panel lines
I like black panel lines no metter what
![]() But then again I work with rally cars only and it is a little different story then the regular, one colour cars. I don't like black panel lines only on yellow cars, but I love them on white ones. This is my Corolla with nice black ones done by simple thined MM enemal SG black. |
