Go Back   Automotive Forums .com Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 03-05-2005, 08:35 PM   #1
toyosam
Unhappy frequent stalling
i have a '95 camry w/ 112K on it & it stalls frequenty... it happens when i brake/slow down or stop at the light... it riddles, stalls, and starts back up within 10-20 secs... any ideas what's causing stalling???
toyosam is offline   Reply With Quote
Old 03-05-2005, 09:28 PM   #2
Clifford Peak
Re: frequent stalling
hello all,,from a newbie,,,i am having the sam problem with my 87,,complete tune-up has been done and i replaced the fuel damper.still wont idle and refuses to respone to the go pedal,,,and of course the problem is intermintent...driving me nuts
Clifford Peak is offline   Reply With Quote
Old 03-06-2005, 07:24 PM   #3
Strider327
Send a message via AIM to Strider327
How is the idle normally? In most cases it can be a ignition problem but if you guys already looked into that, then my next guess would be a dirty throttle body. If not that, check the ECT Engine Coolant Temperature sensor, this has been known to shut the car off out of no where. Also check the ISC valve (Idle Speed Control Valve) Hopefully the following will help.
Good Luck,
Calvin
Strider327 is offline   Reply With Quote
Old 03-07-2005, 01:41 PM   #4
typesix
Check EGR valve for carbon deposits.
typesix is offline   Reply With Quote
Old 03-07-2005, 01:43 PM   #5
burchard
Good Luck,
Calvin
If you have not cleaned the EGR before, there is a good chance that is your EGR.
If cleaning the EGR does not solve your problem, the ECT might be the problem.
good luck
burchard is offline   Reply With Quote
Old 03-08-2005, 01:07 AM   #6
Clifford Peak
Re: Re: frequent stalling
Thanks for your help,,,and no it does not act up all the time,,,thats what be driving me nuts.for the most part it is a great car,,,has new brakes and CV joints,battery and tune-up,and since it was given to me the price was right,,,hope to get it running well enough for a work car,well thanks again this place is great.
Old 03-08-2005, 09:55 PM   #7
toyosam
Thumbs up Re: Re: frequent stalling
good luck
Replaced the EGR valve, cleaned ISC Valve - $600. Did not check the ECT... however, stalling seemed to stop after first 2 things were done... if occurs again, will check ECT...
thanks, Calvin!
