Go Back   Automotive Forums .com Car Chat > Chevrolet > Malibu
Old 02-22-2005, 06:31 PM   #1
autobody4u
lamp dimmer module location plz reply!
I am working on my cousins '03 malibu sedan. The instrument panel lights stopped working on him. The instrument panel fuse on the right side of the dash has no juice when switch is on and I know the switch is feeding because the park/head lamps work. I've checked the dimmer switch and it is fully functional. I just need to know exactly where this lamp dimmer module is located so I don't have to tear the whole thing apart to fix. Any help regarding this matter will be greatly appreciated! Thanks!
autobody4u is offline   Reply With Quote
Old 02-22-2005, 09:18 PM   #2
e2helper
Re: lamp dimmer module location plz reply!
Dimmer module is located on left side of instrument panel. Service procedure says you just have to remove the close-out panel and you should be able to look up and see it.
Looks like it is more towards center of vehicle attached to some bracket for HVAC system
e2helper is offline   Reply With Quote
Old 02-22-2005, 09:43 PM   #3
autobody4u
dimmer control module
thanks a lot for the info. I was just working on it in the driveway this evening and it got dark on me so I'll check out what you told me tomorrow. What do refer to as the closeout panel by the way? Thanks for the help!
Eric
Old 02-22-2005, 10:22 PM   #4
autobody4u
found it
ok i decided to put the ol' flashlight to good use since I already had the left IP disassembled. I looked right at that thing earlier this evening and didn't realize that was what I was looking for. Its in a tight spot, but I'll take it out and test it tomorrow. Thanks again for your help. Your info probably saved me a lot of unnecessary disassembly!
Eric
