Go Back   Automotive Forums .com Car Chat > Buick > Skylark
Old 12-19-2004, 07:06 PM   #1
rwfisch
1992 skylark leaking water
I have a 1992 buick skylark, Just bought this car. I was wondering if this is a common problem with these. There is a puddle on the front drivers side, sometimes in a heavy enough rain, it moves to the back Dr. side. I put some cauking under the cowl, still leaks. I know these leaks can be difficult to trace, so if anyone has a similar problem please let me know. Thanks
rwfisch is offline   Reply With Quote
Old 12-20-2004, 03:29 PM   #2
joedogg
Re: 1992 skylark leaking water
Your problem is with the firewall. There is a hole rusted through it and the rain coming through that. I had a '93 that did the same thing and my brother's '93 Grand AM (sister car) also did it, but eventually his firewall got so bad that the steering came loose from it. You could try to find the leak and bondo it up from either the outside or inside.
joedogg is offline   Reply With Quote
Old 12-20-2004, 06:41 PM   #3
rwfisch
Thanks so much for the info. It will save me a ton of time ripping apart the dash
Old 12-21-2004, 04:48 PM   #4
rwfisch
Found it! right below the steering column where the floor meets the firewall. Thanks a million!
