Go Back   Automotive Forums .com Car Chat > Honda > Civic | CRX > '88 - '91 Civic | CRX | Wagon | Shuttlee
Old 09-30-2004, 10:49 PM   #1
LSfrankenstein
Banned
oversized fuel injectors
I have a stock car but i put on 750cc fuel injectors and a really powerful fuel pump but now my car doesnt run very good for some reason. im pretty sure it is my exhaust does anyone have any ideas for an exhaust to combo with this upgrade?
LSfrankenstein is offline   Reply With Quote
Old 09-30-2004, 10:50 PM   #2
look its holiday
Re: oversized fuel injectors
you're a retard, you obviously need more fuel
add a fuel pressure regulator to crank up the fuel pressure all the way, that should fix your problem
look its holiday is offline   Reply With Quote
Old 09-30-2004, 10:51 PM   #3
mellowboy
Amy dragged me here...
mellowboy's Avatar
Send a message via Skype™ to mellowboy
Ok get RID OF THOSE FUEL INJECTORS! Thats way too much flow man. You dont need that much for a stock engine! Hell you dont them period for a stock engine. Put your stock ones back on.
mellowboy is offline   Reply With Quote
Old 09-30-2004, 10:52 PM   #4
LSfrankenstein
Banned
i forgot to tell i already added an aem fuel pressure regulator so i should have enough fuel. my freakin check engine light is on now too wtf is going on?
Old 09-30-2004, 10:53 PM   #5
look its holiday
check for a leak somewhere something fishy is going on there definitely
Old 09-30-2004, 10:53 PM   #6
mellowboy
mellowboy's Avatar
You're not getting it. Its causing so much flow your motor can't even handle it. I'm telling you to put your stock ones back on.
Old 09-30-2004, 10:55 PM   #7
LSfrankenstein
Banned
nah i figured it out i think. im going to put a 4" exhaust on to keep it from backfiring so freakin much and get a skunk2 chip to increase my rev limiter so i can rev higher to use the fuel. thanks man
Old 09-30-2004, 10:56 PM   #8
mellowboy
mellowboy's Avatar
Wtf? What you got done on your motor?
Old 09-30-2004, 10:59 PM   #9
mellowboy
mellowboy's Avatar
You gotta do alot more research. IT looks like you dont know what your doing at all. Supras doesn't even use 4 inch exhaust! Its not gonna help stop the backfiring. YOu gonna loose alot of pressure.
Old 09-30-2004, 11:02 PM   #10
LSfrankenstein
Banned
Re: Re: oversized fuel injectors
You obviously know nothing about engines. the more fuel u need the bigger exhaust u need its that simple. plus i took the filter off my intake to add more air which is fine since its summer time all the filter does is stop water
Old 09-30-2004, 11:04 PM   #11
mellowboy
mellowboy's Avatar
LOL are you serious?!
Old 09-30-2004, 11:10 PM   #12
LSfrankenstein
Banned
yes. everyone knows that the more fuel u get the more horsepower your car will get. My LS vteck frankie puts out 250 by itself and now im prolly pushin around 330 hp and 450 ft-lb of torque just by my fuel upgrades alone. once i get my shit runnin good ill be smokin fools. im takin it to get dyno tuned tomorrow
Old 09-30-2004, 11:12 PM   #13
mellowboy
mellowboy's Avatar
Ok whats done exactly? those numbers seem funky.
Old 09-30-2004, 11:16 PM   #14
SiGNAL748
SiGNAL748's Avatar
Send a message via AIM to SiGNAL748 Send a message via MSN to SiGNAL748
the mere fact that you say your honda motor is putting out more torque than it is horsepower nullifies your statement completely
SiGNAL748 is offline   Reply With Quote
Old 09-30-2004, 11:21 PM   #15
vladlos
vladlos's Avatar
Send a message via AIM to vladlos
whats an ls vteck frankie?
vladlos is offline   Reply With Quote
