Go Back   Automotive Forums .com Car Chat > Land Rover > Defender
Old 09-04-2004, 08:15 PM   #1
jwa
No clutch peddle movement
[color=royalblue][font=arial]
Hi there, havnt visited the site for a while so it has changed (well done). I have a problem with a Defender clutch??? The peddle will not move at all, I am thinking it is the clutch plate broken up, but if anyone out there can point me in another direction I would be happy. I dont fancy the idea of taking engine or gear box out to find out. Help! has anyone had a problem.
Jwa
jwa is offline   Reply With Quote
Old 09-07-2004, 03:39 PM   #2
Cbass94
Cbass94's Avatar
Send a message via MSN to Cbass94
Re: No clutch peddle movement
So, do you mean it doesn't push down at all? or that it doesn't engage when pressed down? If it is the latter, I woudl suspect a bad clutch master cylinder.
Cbass94 is offline   Reply With Quote
Old 11-01-2004, 05:22 PM   #3
Ebooters
Hi the clutch fork sounds like it has burst through remove slave clyinder if the push rod is not sticking out of the bell housing the fork has burst if so gearbox out
Ebooters is offline   Reply With Quote
Old 01-11-2005, 11:01 AM   #4
demiru
am sorry but it sounds like her pressure i s gone had the same prob a while back and had to bring the gearbox down..all the best
demiru is offline   Reply With Quote
