| Latest | 0 Rplys |
General Discussion All general comments or enquiries go here. Website, club oriented, or general Skyline banter. |
#1 | |
Pulling an Engine, need help.
First off, sorry for putting this in the US section but there are a lot more people in here so....
My situation is apparent by the photo in my signature block. Basicly I need to pull this engine out in the next week or so and I have NO clue what to do. Never pulled an engine before. Just looking for some tips, advice, instructions, pictures. hell, anything to help a clueless bastard out. Cheers.
#2 | |
Master Connector
Re: Pulling an Engine, need help.
Do you want to do it the easy way? or the proper way?
Easy way: Jack the front of the car up as far as you can, at least enough to clear the height of the engine when its lying on its side. Get some side cutters and cut EVERYTHING you can find that is attached to the engine, wiring loom, fuel lines, etc etc. Cut the exhaust Unbolt the engine and gear box mounts, making sure your not under the engine at the time. Unbolt the front subframe and steering linkage, and the lower control arms from the uprights. Let the whole lot drop on the ground and drag it out from underneath. Its quick and nasty and the common method used by wreckers who only just care about the engine, and only the engine. The Proper Way: Take the bonnet off the car Carefuly detach everything you can find attached to the engine. Unplug all of the loom, and undo and remove all the fuel lines, clutch fittings etc. Undo the exhaust. Then useing an engine hoist to surport the engine and gearbox unbolt the engine mounts and carefuly raise it out of the car. You might also have to remover the raditor, and possibly either of the Manifolds. Drain the oil out of both the engine and gearbox first will also make things easier. Also removing as many of the auxleries as you can before lifting the engine will help, things like the A/C and P/S can be removed from the engine and left hanging in the engine bay.
#3 | |
Gonna try to do it the right way (somewhat). here's what I did today (with the invaluable help of friends).
![]() Go here for more pics: http://blacklinux.com/pages/public/c...ne/enginepull/ or my site: http://blacklinux.com/pages/public/cars/skyline/
#4 | |
Should make it a little easier to lift considering it's only gonna have to go up like 4 inches. Now that I see the car like this, I'm not afraid of this job anymore. I don't know why I was, just cause I've never done anything like this before. But, taking it apart is a lot easier than putting it back together I guess :-) Cheers guys, thanks for all the help and advice in general over the past few months. To the few in this forum that are here to help, you guys really do a great job of answering questions and giving advice.
![]() ![]() Thanks Barnes
#5 | |
Ive heard its hard to pull Skyline motors because the wiring is weaved all throughout the harness. I dunno if this is only the GTR models or not, I read that from some guy that was doing an rb swap.
EDIT: forgot to mention what car he was putting it in ![]() |
#6 | ||
Master Connector
Re: Re: Pulling an Engine, need help.
You really dont know a lot about cars do you? my3rdskyline Its a hell of a lot easier when you cut the front of the car off! ![]()
#7 | |
![]() Join Date: Jan 2004
Very Very important thing that i don't think anyone has mentioned yet is stick little labels on all the wires and everything so that you know how to put it all back together again later on. Trust me, this could save you hours and hours of scratching your head trying to remember what goes where
![]() Its really not that hard pulling out an engine, seriously, its an easy job just may take a bit of time on your first time.
![]() 93 camaro Z28 R.I.P. From this......................to this and this ![]() ![]() check it out at my website "Pain heals, chicks dig scars but glory is forever !" |
#8 | |
Feeling a lot more secure about doing this job, anything I should know before I do the actual pull on saturday?
Check this out: I'm doing this work at typhoon motors on camp foster (a marine camp). It costs $2.50 per hour for a flat spot, or $3.50 per hour for a spot with a lift. These prices include the use of any and all tools including a cherry picker. I went thru 4 cutting wheels today. Total for todays work... 5 bucks. The damn wheels I burned thru cost more than that (but I don't have to pay for them). Sweet deal hu? I'm gonna start doing some more work on my cars more often.
#9 | |
Like what Zwrangler said, label everything.
I normally take of the intake and exhaust, stick a bolt out on the four corners so I can attach the lift chain. There are other ways to lift it, but I always try to do it that way. Other than that, make sure everything is disconnected, and pull that sucker out.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper. |
#10 | |
Master Connector
I was going to mention be careful where you attach the lift straps, but Iv never lifted an RB, and SkyUS covered it.
Oh! One other thing, does the skyline use a slip in drive shaft or is it on a flange? If its slip in then make sure you drain the oil out of the g/box first, or it will spill everywhere when you lift the engine and g/box. If its on a flange, then don't forget to undo it ![]()
#11 | |
im guessing it's slip in. I was planning on draining PS fluid, Engine oil and tranny fluid. anything else I should keep in mind, and could some one with a definite answer tell me if it's slip in or flange before I just have to find out for myself tomorrow? Once again guys, thanks for all the help.
#12 | |
Master Connector
Stick your head underneath and have a look!
If theres a flange with bolts through it then you know its flange type (duh) And if theres no flange then its slip in, and you'll need to make sure you have some protection ![]() As I said above though, draining all the fluids first does make it all easier. But Don't worry about the power steering, just unbolt the pump and leave it in the car, then its once less thing you have to worry about. You'll probobly have to put the car up on axle stands as well. And, Something SkyUSA will be able to answer, are there clearance issues with the sump and front cross member? Most I6 cars Iv pulled the engines out of have been a tight fit around the sump.
#13 | ||
Questions for the future.... http://projectskyline.kicks-ass.net/engswap.html This guy used an R33 GTS25t tranny and an RB26DETT in his R32 GTS-t. For next year I am planning on doing a swap in my silver car. I'm thinking of an RB26DETT or an RB25DET from an R33. I've got a few pictures of the GTR Motor and tranny and the linkage for the front wheels. Do you think an RB26DETT and GTR tranny will fit into my car and be AWD? Or would I be better off just focusing on the engine and tranny, don't worry about the 4wd. I know it would be great for straight line launches. but I'm not so worried about that. My dream for this car would be a state side road course/ track car. If I don't do AWD then what about a serious tubb job? Has anyone seen a tubbed R32? AWD conversion on an R32 GTS-t? I was looking on yahoo auctions japan (well my wife, I can't read japanese) and GTR motors are pretty cheap. like 1500-4500. I saw one kit here for 1500 but the motor was all taken apart. It was in the middle of a stalled overhaul. Hopefully by the time I have the money to do this (ehem, I mean my wife forgot about the car accident and she wont fucking kill me for spending money on my car) I will be able to do something like buying an engine in pieces and build it. I'm really interested in this stuff and would love to learn.But feel like a dumbass sometimes for asking questions like this. But fuck that, so.... what's a good way to start?
#14 | |
1500-4500 thats not bad. Especially nice knowing that since i know we can get them here in the US for about 5 grand for a whole front clip. harness, wiring and everything (some i see include a tranny). One thing that i know the japanese doesnt completly kick our ass on the pricing of something.
#15 | ||
Master Connector
Re: Re: Re: Pulling an Engine, need help.
Its been done, its called a GTR ![]() Im sure you could fit the subframe and enough of the front suspension from a GTR into your GTS-t to make it AWD, but you would have a bitch of a time wiring up the electronics to make it work, and you would still not have the other improvements made to the GTR. (brakes, suspension tuning, body stiffening etc etc etc). What you would have would be an expensive and potentialy unreliably bastard that was not as fast as a GTR, but would probobly cost as much, if not more. I would suggest either spending the money you plan on putting into your GTS-t on a proper GTR as it sounds like thats what you really want.
