Go Back   Automotive Forums .com Car Chat > Honda > Prelude
Old 04-26-2004, 12:07 PM   #1
AcesHigh
Prelude Guy
AcesHigh's Avatar
Send a message via AIM to AcesHigh
Post Prelude Specifications Thread
The old thread I found in search by Veetec pointed to the Preludecrazy.com site. It mostly had info on the fourth gen Preludes. Here's a new thread for FAQ purposes, load it up with as many Prelude specs as you can find. Anything at all, from wheel to speaker size for any generation. Just keep it neat.
1st Generation
Year '79-'82
Model N/A
ENGINE
Type Inline 4
Displacement 1751 cc
Horsepower@rpm (SAE net) MT / AT 72@4500 / 68@4500
Torque (lb.ft.) MT / AT 94@3000 / 94@2500
Compression Ratio 8.0:1
Valve Train SOHC 12-Valve
Fuel Induction System Venturi Carburetor
Ignition System Electronic
EPA Estimate (manual) ??
EPA Estimate (automatic) ??
DRIVE TRAIN
Type Front-Wheel Drive
Manual Transmission 5 Speed
Automatic Transmission 3 Speed
Final Drive Ratio (MT / AT) 3.875 / 4.214
BODY/SUSPENSION/CHASSIS
Body Type Unit Body
Suspension (front/rear) 4-Wheel Independent w/ MacPherson Strut
Stabilizer Bar (mm, front/rear) NA/NA
Steering Type Power-Assisted Rack and Pinion
Steering Wheel Turns, Lock-to-Lock 3.26
Turning Diameter, Curb-to-Curb (ft.) 33.5
Brakes Power-Assisted Front Disc / Rear Drum
Wheels 13" Steel
Tires 175 / 70 SR 13
EXTERIOR DIMENSIONS
Wheelbase (in.) 91.3
Length (in.) 161.4
Width (in.) 64.4
Height (in.) 51.0
Track (in., front / rear) 55.1 / 55.5
Ground Clearance (in.) 6.7
Curb Weight (lbs.) MT / AT 2130 / 2146
Coefficient of Drag (Cd) ??
INTERIOR DIMENSIONS
Headroom (in., front/rear) ??
Legroom (in., front/rear) ??
Shoulder Room (in., front/rear) ??
Hiproom (in., front/rear) ??
Cargo Volume (cu. ft.) ??
Interior Volume (cu. ft.) ??
CAPACITIES
Engine Oil with Filter (qt.) 4.2
Fuel (gal.) 13.2
Cooling System (qt.) 6.4
2nd Generation
Year '83-'87
Model S Si
ENGINE
Type Inline 4
Displacement 1829 cc 1955 cc
Horsepower@rpm (SAE net) 100@5500 110@5500
Torque (lb.ft.) 107@4000 114@4500
Compression Ratio ?? ??
Fuel Induction System Venturi Carburetor PGM-FI
EPA Estimate (manual) 24/32 25/30
EPA Estimate (automatic) 23/30 23/29
DRIVE TRAIN
Manual Transmission 5-Speed
Automatic Transmission 4-Speed w/Lock-Up
Final Drive Ratio (MT/AT) ??
Body Type Unit Body
Suspension (front/rear) Upper Wishbone, Lower Control Arm/MacPherson Strut
Stabilizer Bar (mm, front/rear) ?? yes/yes ??
Steering Type Variable-Assist Power Rack-and-Pinion
Steering Wheel Turns, Lock-to-Lock ??
Turning Diameter, Curb-to-Curb (ft.) 34.1
Brakes 4-Wheel Power-Assisted Disc
Wheels Steel Alloy
Tires ??
EXTERIOR DIMENSIONS
Wheelbase (in.) 96.5
Length (in.) 169.1 172.0
Width (in.) 66.9
Height (in.) 48.6
Track (in., front/rear) 57.9/57.9
Curb Weight (lbs.) (1984)2266/(others)2293 2379
Ground Clearance (in.) ?? ??
INTERIOR DIMENSIONS
Headroom (in., front/rear) 37.3/33.9
Legroom (in., front/rear) 43.2/26.1
Shoulder Room (in., front/rear) 54.5/51.9
Hiproom (in., front/rear) 49.7/47.6
Cargo Volume (cu. ft.) 9.1
CAPACITIES
Engine Oil with Filter (qt.) ??
Fuel (gal.) 15.8
Cooling System (qt.) ??
3rd Generation
Year '88-'90 '88-'91 '90-'91
Model 2.0 S 2.0 Si Si
ENGINE
Type Aluminum-alloy in-line 4
Displacement 1958 cc 2056 cc
Horsepower@rpm (SAE net) 105@5800 135@6200 140@5800
Torque (lb.ft.) 111@4000 127@4000 135@5000
Compression Ratio 9.1:1 9.0:1 9.4:1
Valve Train SOHC, 12-Valve DOHC, 16-Valve
Fuel Induction System Dual Sidedraft Constant Velocity PGM-FI
EPA Estimate (manual) 23/37 22/27 22/27
EPA Estimate (automatic) 21/27 20/26 20/26
DRIVE TRAIN
Automatic Transmission 4-Speed w/Sport-Shift
Final Drive Ratio (MT/AT) 4.27/4.13 4.27/4.36
Body Type Unit Body
Suspension 4-Wheel Upper Wishbone, Lower Control Arm
Stabilizer Bar (mm, front/rear) 25.4/17.0
Steering Wheel Turns, Lock-to-Lock 2.81
Turning Diameter, Curb-to-Curb (ft.) 34.8
Wheels 13-inch Steel Wheels w/Full Covers 14-inch Steel Wheels w/Full Covers
Tires 185/70 HR13 195/60 R14 85H
EXTERIOR DIMENSIONS
Wheelbase (in.) 101.0
Length (in.) 177.6
Width (in.) 67.3
Height (in.) 51.0
Track (in., front/rear) 58.3/57.9
Ground Clearance (in.) 5.7
Curb Weight (lbs., MT/AT) 2566/2606 2639/2674 2690/2725
Coefficient of Drag (Cd) .34
INTERIOR DIMENSIONS
Headroom (in., front/rear) 36.9/34.1
Legroom (in., front/rear) 43.1/27.1
Shoulder Room (in., front/rear) 53.1/51.1
Hiproom (in., front/rear) 51.5/45.1
Cargo Volume (cu. ft.) 11.0
Interior Volume (cu. ft.) 87
CAPACITIES
Engine Oil with Filter (qt.) 5.1
Fuel (gal.) 15.9
>Cooling System (qts., MT/AT) 6.3/5.6 6.7
4th Generation
Year '92-'96
Model S Si Si VTEC
ENGINE
Displacement 2156 cc 2259 cc 2157 cc
Horsepower@rpm (SAE net) 135@5200 160@5800 190@6800
Torque (lb.ft.) 142@4000 156@4500 158@5500
Compression Ratio 8.8:1 9.8:1 10.0:1
Valve Train SOHC, 16-Valve DOHC, 16-Valve DOHC, 16-Valve VTEC
Fuel Induction System PGM-FI
EPA Estimate (manual) 23/29 22/26 22/26
EPA Estimate (automatic) 23/28 22/27 N/A
DRIVE TRAIN
Automatic Transmission 4-Speed N/A
Final Drive Ratio (MT/AT) 4.06/4.29 4.27/4.43 4.27/NA
Body Type Unit Body
Stabilizer Bar (mm, front/rear) 25.4/23.0
Steering Wheel Turns, Lock-to-Lock 2.9
Turning Diameter, Curb-to-Curb (ft.) 35.9
Brakes 4-Wheel Power-Assisted Disc 4-Wheel Power-Assisted Disc w/ABS
Wheels 14-inch Steel Wheels w/Full Covers 15-inch Alloy Wheels
Tires 185/70 R14 87H 205/55 R15 87V
EXTERIOR DIMENSIONS
Wheelbase (in.) 100.4
Length (in.) 174.8
Width (in.) 69.5
Height (in.) 50.8
Track (in., front/rear) 60.0/59.6
Curb Weight (lbs., MT/AT) 2809/2862 2866/2921 2932/NA
Coefficient of Drag (Cd) .33
INTERIOR DIMENSIONS
Headroom (in., front/rear) 38.0/35.1
Legroom (in., front/rear) 44.2/28.1
Shoulder Room (in., front/rear) 54.0/50.6
Hiproom (in., front/rear) 52.2/41.4
Cargo Volume (cu. ft.) 7.9
Interior Volume (cu. ft.) 80.2
CAPACITIES
Fuel (gal.) 15.9
Cooling System (qts., MT/AT) ??
5th Generation
Year '97-'98 '99-'01 '97-'98 '99-'01
Model Base Base Type SH Type SH
ENGINE
Type Aluminum Alloy Inline 4
Displacement 2157 cc
Horsepower@rpm
(Automatic) 195@7000
(190) 200@7000
(195) 195@7000 200@7000
Torque (lb.ft.) 156@5250
Compression Ratio 10.0:1
Valve Train DOHC, 16-Valve VTEC
Ignition System Electronic, w/ Immobilizer
EPA Estimate (manual) 22/27
EPA Estimate (automatic) 21/27 N/A
DRIVE TRAIN
Type< /td> Front-Wheel Drive Front Wheel Drive w/ ATTS
Automatic Transmission 4-Speed w/Sequential Sport-Shift N/A
Final Drive Ratio (MT/AT) 4.266/4.785 4.266/NA
Body Type Unit Body
Stabilizer Bar (mm, front/rear) 25.4/23.0 24.2/23.0
Steering Wheel Turns, Lock-to-Lock 2.887 2.762
Turning Diameter, Curb-to-Curb (ft.) 36.1 37.4
Brakes 4-Wheel Power-Assisted Disc w/ ABS
Wheels 16-Inch Alloy
Tires 205/50 R16 87V
EXTERIOR DIMENSIONS
Wheelbase (in.) 101.8
Length (in.) 178.0
Width (in.) 69.0
Height (in.) 51.8
Ground Clearance (in.) ?? ?? ?? ??
Curb Weight (lbs., MT/AT) 2954/3009 3042/NA
INTERIOR DIMENSIONS
Headroom (in., front/rear) 37.9/35.3
Legroom (in., front/rear) 43.0/28.1
Shoulder Room (in., front/rear) 54.9/50.0
Hiproom (in., front/rear) 52.1/41.0
Cargo Volume (cu. ft.) 8.7
Interior Volume (cu. ft.) 78.4
CAPACITIES
Fuel (gal.) 15.9
Cooling System (qt.) ?? ??
1993 Mazda Rx-7 Touring
Ricer Extraordinaire
AcesHigh is offline   Reply With Quote
Old 04-26-2004, 12:36 PM   #2
AcesHigh
Prelude Guy
AcesHigh's Avatar
Models around the world (this post took forever to type):
USDM = United States
JDM = Japan
CDM = Canada
UKDM = United Kingdom
EDM = Europe
ADM = Australia
NZDM = New Zealand
Fourth generation
USDM / year / engine
S (92-96) f22a1
Si (92-96) h23a1
Si 4WS (92-96) h23a1
Se (95-96) h23a1
VTEC (93-96) h22a1
** USDM h22a1 engines have 190hp. JDM h22a blocks have 200hp.
JDM
Si (92-96) f22b
Si 4WS (92-96) f22b
Si-VTEC (92-96) h22a
Si-VTEC 4WS (92-96) h22a
** So just to clarify, the JDM Si series use the f22b, which has the same bore as the h23a. The h23a (with no numbers) in Japan is a bluetop DOHC VTEC h23 block found in 6th gen (99-00) Accord SiR Wagons. Both the f22b and h23a are exclusively JDM and not found here. Our h23a's have numbers after them.
CDM
S (92-96) f22a1
SR (92-96) h23a1
SRV (93-96) h22a1
UKDM
2.0i (92-96) f20a
2.3i (92-96) 4WS h23a2
VTEC (92-96) h22a
** UKDM Prelude base models have the f20a block, which is also found in the JDM 90-93 Accord 2.0Si. The h23 blocks in the UK have a 2 stamped after them. They are the same as the h23a1 engines.
ADM
S (92-96) f22a1
SRS [4WS] (92-96) h23a1
VTiR [4WS] (92-96) h22a
Old 04-26-2004, 12:44 PM   #3
AcesHigh
Prelude Guy
AcesHigh's Avatar
Re: Prelude Specifications Thread
Curb weights
1988 Honda Prelude 4WS MT 2685
1988 Honda Prelude S MT 2522
1988 Honda Prelude Si MT 2665
1989 Honda Prelude 4WS MT 2741
1989 Honda Prelude S MT 2571
1989 Honda Prelude Si MT 2712
1990 Honda Prelude 2.0S MT 2566
1990 Honda Prelude 2.0Si MT 2639
1990 Honda Prelude 4WS MT 2690
1990 Honda Prelude Si MT 2690
1991 Honda Prelude 2.0Si MT 2639
1991 Honda Prelude 4WS MT 2712
1991 Honda Prelude Si MT 2690
1992 Honda Prelude S MT 2809
1992 Honda Prelude S AT 2862
1992 Honda Prelude Si MT 2866
1992 Honda Prelude Si AT 2921
1993 Honda Prelude S MT 2809
1993 Honda Prelude S AT 2862
1993 Honda Prelude Si MT 2866
1993 Honda Prelude Si AT 2921
1993 Honda Prelude VTEC MT 2932
1994 Honda Prelude S MT 2809
1994 Honda Prelude S AT 2862
1994 Honda Prelude Si MT 2866
1994 Honda Prelude Si AT 2921
1994 Honda Prelude VTEC MT 2932
1995 Honda Prelude S MT 2809
1995 Honda Prelude S AT 2862
1995 Honda Prelude Si MT 2866
1995 Honda Prelude Si AT 2921
1995 Honda Prelude VTEC MT 2932
1996 Honda Prelude S MT 2809
1996 Honda Prelude S AT 2862
1996 Honda Prelude Si MT 2866
1996 Honda Prelude Si AT 2921
1996 Honda Prelude VTEC MT 2932
1997 Honda Prelude Base MT 3009
1997 Honda Prelude Base AT 2954
1998 Honda Prelude Base MT 3009
1998 Honda Prelude Base AT 2954
1998 Honda Prelude Type SH MT 3042
1999 Honda Prelude Base MT 3009
1999 Honda Prelude Base AT 2954
1999 Honda Prelude Type SH MT 3042
2000 Honda Prelude Base MT 3009
2000 Honda Prelude Base AT 2954
2000 Honda Prelude Type SH MT 3042
2001 Honda Prelude Base AT 2954
2001 Honda Prelude Type SH MT 3042
Old 04-27-2004, 12:44 AM   #4
crzyCollegeKid
um....don't mean to flame...but just give them the link to North Texas Prelude Owners Group
http://www.ntpog.org
AND THEIR HANDY DANDY specs page:
http://www.ntpog.org/specs/index.shtml
Not-named-yet:
2011 Hyundai Sonata SE w/Sunroof and Nav in Iridescent Silver Blue Pearl
Claudia (traded-in):
2003 Mitsubishi Eclipse GTS: Pioneer Speakers All Around, Kenwood MP3 Deck, Clarion Equalizer, Boss 4ch. 800W amp, 2 Dual 12" subs with Dual 500W amp, XM Roady2
R.I.P. Jessica
1997 Honda Prelude: AEM CAI - Exedy Full Face Organic Clutch - XACT Streetlite 12.5lb flywheel - DC Sports Short Throw Adapter
crzyCollegeKid is offline   Reply With Quote
