Go Back   Automotive Forums .com Car Chat > Engineering/Technical
Engineering/Technical Ask technical questions about cars. Do you know how a car engine works?
Old 01-07-2004, 08:43 PM   #1
Kamakazze15
Send a message via AIM to Kamakazze15 Send a message via Yahoo to Kamakazze15
pulling out and dropping in engine???
hey everyone...ive never pulled or dropped in an engine before...is there anywhere i can go to learn how or sumtin???
Kamakazze15 is offline   Reply With Quote
Old 01-07-2004, 10:12 PM   #2
ivymike1031
Send a message via AIM to ivymike1031 Send a message via Yahoo to ivymike1031
Re: pulling out and dropping in engine???
high school auto shop class, community college auto shop class, the garage of a friend who is doing it, the library, etc...
Come on fhqwhgads. I see you jockin' me. Tryin' to play like... you know me...
ivymike1031 is offline   Reply With Quote
Old 01-07-2004, 11:59 PM   #3
Kamakazze15
i mean any particular place online?
Old 01-08-2004, 05:39 PM   #4
MustangRoadRacer
MustangRoadRacer's Avatar
don't go to http://www.automotiveforums.com/vbul...d.php?t=172926
that place is no help.
Mustangs are nice, but I'd rather have one of these...
MustangRoadRacer is offline   Reply With Quote
Old 01-08-2004, 06:27 PM   #5
Kamakazze15
Old 01-09-2004, 05:41 PM   #6
Kamakazze15
up.
Old 01-09-2004, 06:31 PM   #7
bustedratchet
I learned at the school of Hard Knox.
bustedratchet is offline   Reply With Quote
Old 01-09-2004, 07:06 PM   #8
Kamakazze15
ok, but is there anywhere i can learn teh basics, like online or sumtin
Old 01-13-2004, 03:25 AM   #9
Sluttypatton
Sluttypatton's Avatar
It's fairly simple, first off, do you want to pull only the motor, or the motor and transmission? Either way, basically what you have to do, is disconnect everything holding the motor/transmission to the car (motor mounts, transmission, crossmembers, driveshaft, hoses, wires) then you attatch a cherry picker to the motor (somewhere solid) and you lift the motor up and out of the engine bay. Remember not to unbolt the engine mounts before the cherry picker is attached and ready to lift, or there is something supporting the motor. You don't want the motor to be unsupported. Just use common sense, obviously anything in the way needs to be removed, and anything attaching to both the car and the motor, needs to be unattached. If you dont care about the car the engine is being removed from (it's going to the wrecker for example), dont bother carefully unattaching the wires and hoses, cut them off (this will save time). It is also a good idea to mark the wires and hoses somehow, so you will know where they go when you are putting it back in (masking tape and a pen are good for this). There are many places you can rent a cherry picker (engine hoist) from, and fairly cheaply too. But you will need basic hand tools, a cherry picker, a floor jack, jack stands...basic shop tools, having someone who has done this before would also be nice, or at the very least you will probably need another helper. This can be time consuming, and you may damage your vehicle. By the way, if you are an idiot, do not attempt this, you may damage your vehicle, or worse, yourself.
If you have any more questions, ask, I will answer to the best of my knowledge. But the first thing you should do is ask yourself a few questions; Do you feel confident that you can do this? Do you have the neccesary tools to accomplish this? Once you have taken this motor out, will you be able to put it back in again(anyone can take it apart, putting it back in can be hard if you don't know what your doing)? Do you have a proper work space (covered garage, with flat, level, hard suface...no gravel)? Can you afford to have this vehicle out of comission for at least a week? And lastly, are you at all mechancially inclined?
Beer tastes better upside down.
Sluttypatton is offline   Reply With Quote
Old 01-13-2004, 05:06 PM   #10
Kamakazze15
Thanx sluttypatton for the huge responce. It helped me alot. Ive got all tools. I got a engine hoist and engine roller. My brother works on cars all teh time and ive seen him pull out his 350 before from his impala, but hes in Chicago at the moment at UTI.
Old 01-13-2004, 07:07 PM   #11
Sluttypatton
Good, at least you have someone you can go to if you hit trouble. You should be alright, but make sure you know exactly what you have to do before you start.
Dropped Razor Blade in Engine wagslick 6 1 10-22-2010 09:16 PM
Heat is out and now engine temp is up... KevInAlaska F Series 5 10-25-2007 11:50 PM
Pulled out our charger engine, and don't know what this means!! xXxRocker5150 Engineering/Technical 5 07-29-2005 07:52 PM
I think I am gonna just pull this engine and drop a new one in. Onimacus '88 - '91 Civic | CRX | Wagon | Shuttlee 4 11-29-2004 02:00 PM
engine pull out or drop down? pudgegagt Off-Topic 1 07-17-2004 01:19 PM
