| Latest | 0 Rplys |
#1 | |
turbo difference
difference in these two exhausts, I mean is the second one worth an extra $300 or does it not really matter? would either be good for a KA24DE? is internal wastegate better than external? is a T3 flange a good size if I'm looking for 225-250hp, and yes I plan on rebuilding the engine first, and it will be a daily driver, hopefully put away for the winter though. thanks for away info
http://www.hksusa.com/products/?id=1670 http://www.hksusa.com/products/?id=1671 do you still need a BOV if you have an internal wastegate?
1989 RX-7 TII --- Just got rebuilt and street ported RB 3" dual exhaust, BNR stage 1 modified factory turbo, FCD, S-AFC II, 720cc secondaries, Aftermarket Turbo inlet duct w/K&N, Hawk HP+ pads HKS Blow-Off Valve, Stainless brake and clutch lines |
#2 | |
the compressor wheel is bigger on the gt 3037. i think the a ka24det will take a while to spool the 3037, the 2835 i think spools up a little quicker.. if im correct the hks s-15 silvia uses the gt30 on its drift silvia..
now wastegates and bov are two different things.. the bov protect against compressor surge.. so it vent the gasses into the atmosphere.. a internal wastegate dumps out the excess exhaust gass when the throttle plate is closed i believe.. so you cannot have one or the other get both! ![]() 1
![]() Shift_BOOST 97 s14 |
#3 | |
sweet, that helps a ton! thanks
#4 | ||||||
Re: turbo difference
![]() Quote:
![]() Quote:
![]() Quote:
have fun and good luck on your project ![]()
Bookmarks |
Thread Tools | Search this Thread |
