| Latest | 0 Rplys |
09-20-2020, 03:56 PM | #1 | |
4L60E Issue 00 Silverado z71
I was stopped at stop sign. When I gave truck some gas to go I heard a loud clunk and now the truck will not move in any gear. No issues prior to this. No slipping no burnt fluid smell. Tansmission only has 46,000 mile on it. It's a Jasper reman and unfortunately the warranty is out. Any ideas what may have happened.? Truck has a 4.8 motor and was running flawlessly until now.
09-20-2020, 06:13 PM | #2 | |
A990 racer
Re: 4L60E Issue 00 Silverado z71
No real way to diagnose this from here, may not be the trans., could be the transfer case, get it checked out.
09-20-2020, 07:59 PM | #3 | |
Your worst nightmare
The 4L60 is notorious for just random failures.
09-20-2020, 08:00 PM | #4 | |
Appreciate the response. Hopefully will get it to the shop tomorrow.
10-28-2020, 08:24 PM | #5 | |
Did you get your truck diagnosed? What turned out to be the problem?
My son has a 2008 half-ton with the 4.8 & 4L60E, his is 2wd. Did about the same thing to him, no warning signs, and we ended up pulling it and rebuilding it. A planetary had destructed, but it was a chain of events that began with a Torrington thrust bearing failure. Shops are expensive to get these trannies done, (and after going through it, I can understand why). Problem is, you don't know if they truly rebuild them, or just replace whatever component had failed, leaving you ripe for another failure soon. If you insist on getting a really good warranty, it probably means you are getting a full rebuild, not a repaired used trans. Any shop who says they can replace yours for $7-800 or less is probably selling you a used junkyard unit.
-Jim 2015 Silverado Crew Cab 2500HD 6.6 Duramax 4x4 2002 Silverado Crewcab HD 2500 6.0 4x4 Sold 281K Great Truck 1970 Chevelle SS454 (Gave to my son 9 years ago for his 18th birthday. Yeah, I know, crazy, right? Thank goodness he doesn't drive it the way I would, -er, did...). 1971 Monte Carlo SS454 Drag Racer. The old girl finally got new paint! 1968 Camaro SS (New race car project). Caged, Tubbed, Back-Half/Ladder Bars. Rolling Chassis (For now). |
10-28-2020, 10:00 PM | #6 | |
There was a shop in the Pittsburgh area that rebuilt these things all the time. They were around $900 plus core. They came with a warranty too. I don't know if they still do it, or even remember their name. I found them when the 4L60E crapped out on my brother's Trailblazer.
10-29-2020, 06:27 AM | #7 | ||
Most reputable trans shops we looked at were around $11-1200 carryout with warranty, and for the full job including remove/replace were over $2K. ,
10-29-2020, 07:38 AM | #8 | |
Yeah, $900 was carryout price. We R&R'd ourselves.
11-02-2020, 07:19 PM | #9 | |
loud clunk probably the drive shaft or rear diff.
you have to inspect the ALL drive train fluids every oil change and grease the front steering components... use dexronVI DO NOT USE DEXRON III !!!!!!!!!!!! IN TRANNY,.. |
