Thread Tools Search this Thread
Old 02-26-2016, 02:32 PM   #1
Lambo003
Lambo003's Avatar
DIY Chrome Foil Decals
Been wanting to try this for some time but never got around to gettin' the supplies.
I was looking for a company that makes custom foil transfers such as those in some of the better kits and kept coming across sites for heat transfer foils for clothing, paper crafts and such.
Paper crafting have toner reactive foils (in every color of the rainbow) however, they were meant for paper.
Just for S&G's I wanted to try the application on clear decal film.
Here are the first results of just "winging it" . . . I literally printed them out, ran them through the laminator with the foil. Then messed around with no clear coating and clear coating the decals.
Again, I was just winging it so the results aren't completely perfect.
Just wanted to share.
First I took some artwork from the net.
I filled all the emblems in black with photoshop and added a few other detail pics I drew up for future photo-etching projects just to fill a small sheet. I then printed them on clear decal film with my laser printer (this won't work with inkjet printers).
I then put them between a folded piece of plain paper with the foil covering the printed image and ran them through the laminator 3 or 4 times.
When I opened the paper I could see the image in the foil carrier. When I removed the foil this is what I was left with.
They look like a dull silver here but that's just the camera angle and I was using a cellphone camera.
Back side of the foil
At this point I let them cool, trimmed one of the decals and began dipping it in water (no clear coat). It almost worked as-is but, some of the toner chipped away from the decal paper.
I then clear coated the rest of the sheet. I was expecting the foil to dull a little due to the clear. Rather, it seemed to enhance the chrome look to them.
Not only did the clear enhance the decals but it also kept them from chipping.
Also note that these were printed using inkjet decal paper rather than laser. So I'm sure the fixative on them contributed to some of the chipping. Using laser decal paper ya might not have to clear them.
I also forgot to clean the images using a low-tack masking tape while rushing.
You simply place tape over the foiled images and remove. This will take care of any stray foil bits, covered areas that shouldn't have foil and clean up any ragged edges.
The also look a little grainy in the pics but it really is minimal and they are quite smooth and very shiny.
So for the first try, doesn't look that bad. . .
There are all kinds of tips and techniques online for using toner reactive foils. I'll keep experimenting to try and improve on them.
Since the clear worked so well, I'm also going to try an overlay of inkjet printed images to place over the foiled decal shapes.
Those will carry some of the finer details in the very first pic. I'll also be adding color to some of those.
*edit
An important tip I forgot to mention is to let the decal completely cool before removing the foil after it comes out of the laminator.
I did not do this above and that's why some of the toner is showing in spots and it's not as smooth as it should be.
Chuck
Lambo003 is offline   Reply With Quote
The Following 5 Users Say Thank You to Lambo003 For This Useful Post:
ataschner (02-27-2016), Big Pat (05-12-2016), kaisers_phoenix (02-26-2016), kbx (02-27-2016), willimo (02-27-2016)
Old 02-26-2016, 02:37 PM   #2
Lambo003
Lambo003's Avatar
Re: DIY Chrome Foil Decals
Excuse my dusty model. . . My 3 year old grandson loves to hug my cars lol
Chuck
Old 02-27-2016, 12:44 PM   #3
corvettekid_7684
Brilliant!
corvettekid_7684 is offline   Reply With Quote
Old 02-27-2016, 07:26 PM   #4
willimo
Sweet, sweet tiny Hondas.
Woah, wait, this is incredible! What an idea! Big thank you for sharing!!
Old 02-28-2016, 07:24 AM   #5
Lambo003
Lambo003's Avatar
Thanks guys
I wanted to try it using cleaner images and the overlay technique as mentioned in my first post. Specifically with text.
I Photoshopped some text real quick to get the outline. ("firehouse" is just the name of a font I came across because I was thinkin' of the gold leafing text done on fire trucks)
I printed them out as seen (2 sets of each), split the decal and ran the solid text through the laminator with the foil.
Then lightly cleared each and allowed them to dry for an hour or so. . .
I dipped 'em in water putting the solid text down first. Allowed it to set-up a bit and then put the outlined text over the solid.
(decal isn't silvering, It's the reflection in the gloss clear and the substrate is a textured semi-gloss black plastic sheet)
Hard to photograph shiny material but they're just as reflective as in the first few pics and look much better in person.
I also half-assed tried to do a turning effect on part of the lettering with 0000 steel wool before they were cleared but, needed to make a smaller tool to pull that off.
I did work though and the foil was quite durable.
They also sell Toner Pens that work with these foils and would allow ya to freehand foiled images.
Still gonna keep experimenting using cleaner images and better software.
Chuck
The Following User Says Thank You to Lambo003 For This Useful Post:
chris24 (04-01-2016)
Old 02-28-2016, 02:32 PM   #6
star21
Great ideas! Looking forward to your updates!
star21 is offline   Reply With Quote
Old 02-28-2016, 09:33 PM   #7
Lambo003
Lambo003's Avatar
I'm building anther AMR Lambo 350 GTS and the kit headlights are horrible.
Cast in clear resin, the parts in the kit still weren't even fully cured and typically yellowed.
So this was my plan to replicate new headlights using this method.
I drew up the artwork, printed multiple copies and foiled the solid black shapes.
I then layered the decals and allowed them to dry.
Once they were dry I was able to sand the edges for a perfect fit.
I then domed the assembled decals with an optically clear UV curing resin (Kind of like what bonds LCD displays to digitizers in cellphones).
It dries quickly, crystal clear, is rock hard and available in different cure rates from a few seconds to 10 minutes.
Love the stuff. Good for attaching all kinds of parts clean and fast. Works great for photoetched and clear parts
Here are the results from different angles. . .
Thousand times better than the kit lights IMO
Paint is Tamiya TS58 Light Pearl Blue with Testors Wet Look. Dust is not in the paint, it's just been sitting out curing.
Chuck
Old 03-02-2016, 08:57 AM   #8
Lambo003
Lambo003's Avatar
I ordered laser paper (I was using inkjet in the above posts) and additional foils in several colors.
I'm going to try other manufacturers too.
So far I've been using Minc foils which are dirt cheap (under $5 bucks for the small roll about $15 for the large) and Pulsar.
One color in particular caught my attention.
White pigment TRF for printing in white.
I also ordered Pulsar Pro's PCB "Fab-in-a-Box" kit which uses the same system for etching PC boards (photoetching without the photo resist chemicals!)
http://www.circuitstew.com/howto/pcb_fabrication.html
At some point I'll also try Pulsar's Dry Transfer Decal system with the foils but, from the how-to videos, it takes a little bit longer and is more extensive than I want really to deal with at the moment.
I just wanna print the damn decals out, foil 'em and be done with it. lol
As far as the overlays with inkjet printed decals, same transparency problem they've always had. The images were fine but the chrome was so bright it washed them out. Granted, they were tiny images (the smaller Touring badges seen in my first post were about an 1/8th of an inch).
So for now, waiting on laser paper to try toner images for coloring.
Will update with results as soon as I get the stuff.
Chuck
Old 03-04-2016, 07:02 AM   #9
MPWR
Image Hosting Exceeded
MPWR's Avatar
What a cool idea!!
Added to the How-to list.
PHOTOBUCKET SUCKS
Sorry for my por Englisch!
MPWR is offline   Reply With Quote
Old 03-30-2016, 09:47 PM   #10
Brandon Miller
Send a message via AIM to Brandon Miller
I have Pulsar's foils as I was going to try the white myself. None of the foils are working. In fact they even pull the toner from the decal paper. Pulsar has told me their foils will not work on the laser decal paper.
Brandon Miller is offline   Reply With Quote
Old 05-12-2016, 09:06 PM   #11
Big Pat
Holy moly... Did I really see WHITE as available?
Does that mean I will not have to sell a kidney and buy an Alps printer?
Excited, I am!
Big Pat is offline   Reply With Quote
Bookmarks
Search this Thread:
