Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer > Problem Diagnosis
Old 04-21-2015, 12:05 PM   #1
Brndo
2002 Blazer Rear Wiper Stuck Then Slow
I have 2002 Blazer 4wd LS. Once, the rear wiper did not move when I turned on the switch. I did not hear any noises. I pulled the fuses and left it until I had time to check it. When I got around to checking it I replaced the fuses and turned on the switch. The wiper went up about ¼ of the way and then stopped. I jumped out and pushed it by hand. It then started working but seemed slow. Any ideas? If I wanted to try to lubricate it somehow, where would I start? Inside the tailgate somewhere or outside? What about lubrication for the motor itself, the shaft somewhere or the gears? How are they accessible? Thanks.
Brndo is offline   Reply With Quote
Old 04-27-2015, 12:20 PM   #2
Brndo
Re: 2002 Blazer Rear Wiper Stuck Then Slow
Never mind...I fixed it. I pulled the rear wiper motor and sprayed penetrating oil on the end of the wiper shaft and let it set for a while. In hindsight, I may not have had to pull the motor to do this but it works great now.
I also could not get any wiper fluid out the back. I could hear the pump working but nothing came out. I cut a sharp point on the end of some 0.065” line for a string trimmer and fed it through the washer fluid line in both directions several times. That works great now too.
Tags
2002 , blazer , motor , rear , wiper
