Go Back   Automotive Forums .com Car Chat > Chevrolet > Lumina
Old 02-08-2014, 10:18 PM   #1
bsr2002
Smile Catalytic Converter No Welding
I called several muffler shops and they said they wouldn't weld my cat at the down pipe and they would only install the direct fit.
If that's the case I would install a direct fit myself.
Anyway, I couldn't afford the direct fit and already had the cat.
I used a chain pipe cutter so I could get the cleanest cut I could. The front of the cat slipped in snug at the down pipe, the back of the cat 2.25" was going into 2" pipe so I had to get a pipe reducer.
Once I put in the reducer I put on a strap band clamp and used some quick steel putty for a seal.
I tried to put a band clamp at the front but it wouldn't fit because of the curve of the pipe. I ended up reluctantly using a u-bolt (not pictured) but still came out nicely.
2003 Trailblazer LS 4.2L
www.facebook.com/bennyrillo
bsr2002 is offline   Reply With Quote
Old 02-09-2014, 07:51 AM   #2
Tech II
Re: Catalytic Converter No Welding
When you cut that front pipe, did you cut it as close to the weld near the cat?
If you did, you should not have had a problem with the installation.....
Tech II is offline   Reply With Quote
Old 02-09-2014, 09:31 AM   #3
bsr2002
Yes I did.
http://s123.photobucket.com/user/bsr.../cat2.jpg.html
Old 02-09-2014, 09:49 AM   #4
Tech II
Looking at the picture, it looks like the piping on the new cat is bigger that the old one?
Old 02-09-2014, 03:49 PM   #5
bsr2002
Yeah it was 2.25" on both sides, I had to use a pipe reducer for the back because it was 2.00".
Tags
catalytic , chevy , converter , lumina
