Go Back   Automotive Forums .com Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-06-2014, 01:50 PM   #1
seanmichael72
Cool no spark, seldom starts, then stops, 93 eclipse
Was up til 5am reading through these forums. Can't find my answer. I have 93 2.0 non Turbo eclipse, ran fine for a year, started having trouble, replaced fuel filter, ran fine, then began the nonspark problem. I could occasionally make it start by pulling neg bat terminal and replacing it. Twice I got it to start by fulling fuses and putting them back. Now, nothing. I have voltage to my coil pack or whatever my plug wires are coming from, but nothing coming out the other side. I've been told it can be crank post sensor, but then I've been told not if I'm getting voltage to ignition unit. And then, there is the occasional start, out of nowhere, that has lasted anywhere from 2 days to 2 minutes. Please help. Thank you - Sean Michael
seanmichael72 is offline   Reply With Quote
Old 01-06-2014, 05:22 PM   #2
seanmichael72
Re: no spark, seldom starts, then stops, 93 eclipse
Could it be a short to ground between my CAS and ecm? Its gotten progressively worse, like it rarely starts, and only after I do a number of fumbling around with things, but when it first started, I could pull the key from the ignition, put it back in, and vroom vroom. My engine shakes, as the front mount is gone bye bye, so it could have gotten worse? I so, where? If not, what?
