| Latest | 0 Rplys |
04-01-2012, 11:22 AM | #1 | |
Engine oil leak -2002 venture
My 02 venture is leaking engine oil. I put out a piece of cardboard underneath and it is leaking in the center front. I had an oil change 4 months ago and I checked oil today and it was dry. So, I'm assuming in 4 months the engine oil all leaked out. What could be causing this? I do smell a slight oil burning underneath the hood. It is slight but there for sure. I'm afraid to know the cost of repairs for this since money is pretty tight right now.
04-01-2012, 01:25 PM | #2 | |
Re: Engine oil leak -2002 venture
we can't really see the engine bay and underneath your vehicle to properly guess where the external oil leak is at...
keep an eye on your oil level, not just once every 4 months, but at least weekly, NO, DAILY until you can have it properly diagnosed and repaired you don't want to seize up your engine like my neighbor did & turn your engine into a boat anchor!!! you can have someone clean the oily areas from underneath the engine, then keep an eye on where it's actually leaking from or add a uv dye to find the leaks |
The Following User Says Thank You to ricebike For This Useful Post: |
baby141 (04-02-2012)
04-02-2012, 02:12 AM | #3 | |
The oil pressure sensor is located above the starter and is a common source for leakage. You can reach down from above to feel if it's greasy there. Other possible sources for the leakage is the valve cover gasket or the gasket for the oil cooler behind the oil filter.
Sent from my Samsung Galaxy Note using Tapatalk |
The Following User Says Thank You to sverker For This Useful Post: |
04-02-2012, 07:59 AM | #4 | |
I agree with sverker. The oil pressure sensor is easy to check, just under the exhaust manifold and above the starter. If you have allowed your engine to run with the oil so low as not to measure on the dip stick, the low oil light should have come on also.
If you want to avoid spending lots of money on repairs, its time to start being more diligent in checking the oil/coolant in the engine. Start with an oil change and while you are changing the filter, clean the area under the filter so you can keep watch on it for leaks. Then check it every couple days for level and to see if you can spot the leak. |
The Following User Says Thank You to merc81 For This Useful Post: |
04-02-2012, 08:57 AM | #5 | |
thanks for the great advice. I'm taking it in for service tomorrow. The oil light did come on but I ignored it because ironically I am due for an oil change and the indicator was at number 5. It was doing the count down and when it gets to 0, I would have taken it in for an oil change and also to get my snow tires off.
04-02-2012, 09:00 AM | #6 | |
What should I expect in terms of repair costs if it is the oil sensor pressure? I will keep you posted when I am back from the mechanics tomorrow. Thanks for your help!
04-02-2012, 10:24 AM | #7 | ||
Please note that nobody is saying you need a sensor, only that its a common source of oil leaks. You need to change the oil and then pay attention to where the leak is coming from before thinking about changing any sensors. My money is the oil filter area is where its leaking, but my recent experiences with this engine prove that I have no crystal ball either and you need to pay careful attention to where the oil seems to be coming from. . . |
04-02-2012, 10:36 AM | #8 | |
It took me under 10 minutes to change the sensor, which included rotating the engine back slightly to more easily reach the sensor from above. You need a 27 mm tall socket.
As merc states, it's not certain that it's the oil pressure sensor that is the problem in your case so try to diagnose from where you have the leak. If it is this sensor then it will be greasy on and above the starter and you can also disconnect the electrical connector to the sensor and see if there is oil inside it. |
04-03-2012, 12:04 PM | #9 | |
Just got back from the mechanics to fix an engine oil leak. He says he had to remove and install crank shaft seal, $20 for the part and $70 for 1 hour of labour. Does this sound right? What is this seal? I just parked the van and left a piece of cardboard underneath to see if the problem has been fixed. Your advice is appreciated.
04-03-2012, 12:27 PM | #10 | |
I've never seen that myself but as I've heard it's not uncommon. Sounds like a reasonable price also, keep an eye on if you continue to loose oil if not then it's solved.
04-03-2012, 01:01 PM | #11 | |
I just performed that job about a week ago for a friend. The oil seal sits around the rotating crank shaft pulley and the timing chain cover. Its a normal part to wear out but I didn't mention it since you said the oil was coming from the other side of the car, not the passenger side.
To do the job, you remove the tire, a plastic splash guard, and use a tool to remove the pulley. Takes about an hour. Sounds like a reasonable price to me. |
04-03-2012, 08:16 PM | #12 | |
So I parked my van for the last 3 hours. I put a cardboard underneath. I just checked and noticed a small pea size drop of oil on the cardboard. Is this normal given the van is 10 years old. Or, should there be no oil drops at all. Should I take it back to the mechanic who just replaced the seal today?
04-04-2012, 02:26 AM | #13 | |
Did you note from which side of the engine the oil had dripped based on its position on the cardboard? It doesn't necessary mean that you still have a leak, could be oil from the old leak that dropped on the subframe.
I would probably give it a good shot from below with anti-grease (what is the correct word in English?), then take it to a washer with a good underneeth cleaning. Then keep an eye on the oil level and if you continue to have leakage. Small drops can be considered normal for an engine of this age but any substantial leakage needs to be taken care of. Also pay attention as much as possible to from where you get the oil drips, that will help diagnose it. Sent from my Samsung Galaxy Note using Tapatalk |
04-04-2012, 08:46 AM | #14 | |
Thanks for your time in reading my posts and helping me out. That is great! The oil seems to be dripping from the same spot as before I got it "repaired". It drips from the center front and slightly over to the passenger side. It drips while parked and also when idling. It doesn't seem to be as much as before the repair so maybe there is another leak somewhere? I will keep an eye on it but it is so frustrating. I heard something about the "master seal" going on these vans and if that happens your van is toast. Is this true? I'm not sure what is meant by the master seal but is that what I just had repaired? I had the crankshaft seal repaired.
04-04-2012, 09:00 AM | #15 | |
Center front towards the passenger side would likely be under the oil filter. Did you have a oil & filter change also? There is a oil cooler behind the filter (merc81 knows all about that one ) and some seals that can leak. You should have the engine and the subframe beneth it cleaned, then it's much easier to find where it comes from.
