Old 02-26-2012, 08:13 PM   #1
Porsnatic
Testors/Fujimi Ferrari Dino 246GT
This time I'll be doing this classic and historic car that Enzo did to honor his only late son, and the only one didn't wear the Ferrari badge. The kit I'll be using is a Fujimi Kit that Testors re-boxed in the late 80's with 200+ parts. As an interesting addition, I 'll be using also the awesome detailing kit from Model Factory Hiro with around 125+ more parts. As always, Hiro standars bring us a quality multimedia kit with lots of parts in white metal, vacuuformed glass, turned parts, an exquisite photo-etch set, etc. To add for a little push, parts from Hobby Design and Top Studio will also in this build....So, let's start...
Here's the great Model Factory Hiro Super Detaling kit with lots and lots of parts.
close view:
Some more aftermarket help:
I'll be starting with the nice casted white metal valve covers. The one at the left had already received the dremel's wire brush treatment:
The other parts will do the combo for the clinder heads:
Something its has been already polished and glued:
Now is the turn for the transmission...5 parts will do the completed part:
All the components of the engine..cilinder heads, transmission, engine block, distributor, weber carburators.
The exhaust headers also made of with metal, the ones at the right were already polished, the ones in the left still waiting:
Some more parts like the air cleaner, oil filter, engine mounts, starter, rear axles are already cleaned and mounted for painting. Here we can see all the parts together:
Some parts already painted with some different kinds of metalizers paints:
As an interesting add-on, the rust dust on the thinner can will also be added to the party..nothing looks more real like the real thing:
Finally everything painted and glued together:
This is something will enhance the engine but, will give me a little of hard time of work. For the spark plugs boots I will place a .6mm stainless steel tube inside another .9mm one. The stainless steel tubing is so hard that any knive or cutter can do the job. I used a diamond dust disc with my Dremel and it could be done...
After some hours, the tubing is cutted off and ready. At the top we can see the spark boot sample and at its right the boot I will use fot the distributor caps.
All the parts together and ready to be painted:
Here more components for the suspension, exhaust system, chassis, gas tanks, etc.
Everything inside the dehydrator already painted:
The engine over the chassis...remember what I told you about the real look or real rust dust?...
More of the chassis parts and some plumbing were added:
This is it..for now.
Porsnatic is offline   Reply With Quote
Old 02-26-2012, 10:17 PM   #2
corvettekid_7684
Re: Testors/Fujimi Ferrari Dino 246GT
Wow! Very impressive work on an impressive lot of parts! I'll be following
corvettekid_7684 is offline   Reply With Quote
Old 02-27-2012, 12:34 AM   #3
nugundam93
Blarg! Wort Wort Wort!
impressive work! the real rust sure beats any painted-on effect anytime
olly olly oxen free
nugundam93 is offline   Reply With Quote
Old 02-27-2012, 03:04 AM   #4
euro_z
euro_z's Avatar
that looks great so far, how did you apply the real rust?
euro_z is offline   Reply With Quote
Old 02-27-2012, 09:46 AM   #5
Porsnatic
Thanks for all your kind comments, buys..I used a tiny cotton swab from Gunze Sangyo and then rubbed it a little bit, spreading it all over the parts.
Old 02-27-2012, 03:53 PM   #6
chaos
AF Premium User
chaos's Avatar
Wow looks fantastic so far. Looking forward to more updates as you go along!
chaos is offline   Reply With Quote
Old 03-06-2012, 12:30 PM   #7
Porsnatic
After some days working on the model, here are some updated pictures...
Here we can see different shots of the engine now with some hoses and the bands:
The bottom of the chassis plus the engine:
For the front compartment, I added some plumbing for the brake master cylinder and scratchbuilt the battery connectors out of plastic...
Here I started to take advantage of the great Model Factory Hiro detailing kit, I started shaving the radio buttons and placing the radio photo-etch face. I save the buttons and glued them over. Some of the switches algo gone to replaced latter with the photo etches ones:
How it looks after being completed:
The turn signal, hi-low beam and wiper selectors also suffered a transformation. I shaved the knobs and used pins as the rod:
Completed:
I used the white metal steering wheel plus the photo etch wheel center for the combo. The base of the steering wheel its the plastic part:
For the seats head rest, I also shaved the plastic rod and again used a pin for the metal part:
Some tape was wraped over the emargency lever in order to get a more real leather look:
A good amount of parts ready to be painted:
Dash already painted plus the steering wheel assembly. I used a product named Dr Toffano Synthaglass Vetero Syntetico that I got from Italy Ebay. This product is used to make plastic glass and gives you a cleaner glass look than white glue or other products around in my opinion. The only problem was that I had to wait wo months to arrive here to Puerto Rico!:
The interior tub after completed:
Both chassis and interior tub meet for the first time:
Old 03-06-2012, 06:01 PM   #8
corvettekid_7684
Great work! I'd like to try that glass product. I can't really tell from the photos...
Old 04-28-2012, 09:40 AM   #9
Porsnatic
This last update will start with some minor, but, important goodies added to the engine.
I added the dry sump oil tank hose:
The expansion tank for the radiator:
The DINO lettering for the cylinder heads, they are really tiny, you guys can see how small it is placed on the top of a penny:
How it looks in place:
With the engine completed, then I moved to the body. Besides the plastic main body and the rear panel that holds the trunk, I will use the white metal’s trunk, engine cover, and the hood.
Test fit:
I will start working the front lower panel, which has plastic and thick bars.
The bars has to go:
The panel was aligned and glued in place.
It glued nicely, but, some care has to be taken. I has a deep seam that has to be corrected with some putty:
Instead of putty I will use a better method, at least to me. I will do a mix of micro ballons with super glue. The result is a plastic hard paste that doesn’t shrink and sands smooth with almost no trace of what was here before:
It was applied all over:
For the rear panel these sanding sticks from micro mark are a great help for the hard shape of these panel:
Here you guys can see how it looks after dry, it almost invisible were it was a seal before:
Going back to the front panel were I removed the plastic grill, I will use the photo etch one from the detail set. I was built from 10 parts:
This how it looks in place in this mock up, big difference, isn’t?:
To help to a more strength union, I added a line of Gunze Sangyo’s Mr Surfacer 500 liquid primer:
In this area I even used some white putty:
Now it looks much better, specially at the rear where I had to re-srcribe and putty the window moulding. Some Gunze Mr Surfacer 1000 thinn primer sealed everything:
After I added the metal primer to the white metal parts, the same surfacer 1000 primer prepared the parts for the white and final primer, since I planned to paint the model in yellow:
This is a great primer with almost no trace of sanding:
Some white primer was shoot direct from the can:
These are the colors I planned to use; Gunze pure yellow, Ferrari Yellow from the Gunze Auto Color line(hard to find), Finisher’s Pure Yellow, and Lemon Yellow.
To me they all looks great, but, the Ferrari yellow looks to “creamie”(correct Ferrari shade) that I didn’t like, and the Finisher’s Pure Yellow its to deep. So I have to decided among Gunze pure yellow and Finisher’s Lemon Yellow…My selection…I will use both!
The Finisher’s lemon is at the top with a glossier look and the Gunze yellow at the bottom with a typical lacquer semi gloss look. The Finisher’s lemon will give a crispier-vivid look while the Gunze will give a solid shine yellow base:
Let’s start the fun…Some color was added first to the recessed areas that will covered when I tape together the doors for an even color:
As a result, I got an even beautiful “supermarket” fresh lemon look:
Giving the body a final light sanding to prepare it for the clear, I discovered something typical of lacquers, the seams at the front and at the rear panels where not hide. I always resolve this using some Dupont Variprime primer as a sealer.
I brushed some Future at the seal but it didn’t work. Then, I could managed the situation, I airbrush a little bit of clear as a sealer, then, airbrushed more clear and finally got the result I was looking for.
Everything looked fine and I airbrushed some Finisher’s Urethane GP-1 Clear, but, again…another surprise, the airbrush spitted some remains of black paint over the left quarter panel…:
I though a light sanding will fix it, but…
I give it a general deeper sanding and could fixed it, then another shoot of paint and finally we were ready to go:
Here you can see the results after I used Finisher’s Urethane GP-1 Clear:
What a great glossy clear…:
After I polished the body, I started to add the details to the body. First I added this photo etch disc that will serve as the base to the plastic lens for the front turn signal. Actually, you guys can notice there’s no trace of the panels seal:
The wipers from the photo etch set...great pair, by the way:
I used the rear lights turned base and the plastic lens, the white metal bumpers were polished to a high shine with the Dremel and some blue magic polishing paste, then were masked for the flat black paint that will double as the rubber, photo etch Ferrari script from the set and the horse one from a Ferrari photo etch set from Crazy Modeler and the license plate complete the rear:
At the hood area I masked everything to paint the rubber seal:
Great results...Can be seen that I gave the same treatment to the front bumpers, I added the Dino emblem, front signals, wipers, foil, rear mirrors and the washers for the wipers that are Model Factory Hiro rivets :
A close up to the wipers and washers area:
The rear mirrors could been polished to a high gloss polished look. Here you can see the un-polished white metal part from were I start, the final polished part, and the plastic part:
For the doors stand bars, I scratchbuilt them using some plastic and metal rod:
The parts already glued in place:
The results:
General views:
The tires received the valve stems from RB Motion:
Finally, the chassis met the body...This a picture from the local IPMS where it took for my surprise a second place...Surprise because the model had the best finish and the best detail in European class, at least to my opinion…judge by yourself… To me the best part is that I was able to finish this great model with over 200+ parts and with a piece of history on its shape!
Old 04-29-2012, 05:16 AM   #10
stratos75
Loser
stratos75's Avatar
Excellent job. Congratulations.
Best regards, Mikhail
stratos75 is offline   Reply With Quote
Old 04-29-2012, 11:17 AM   #11
Hemi Killer
very nice work!
Hemi Killer is offline   Reply With Quote
Old 04-29-2012, 05:04 PM   #12
MidMazar
MidMazar's Avatar
Beautiful model!!!!!!!!
In Progress
Old 05-04-2012, 06:23 PM   #13
MartiniOCP
Absolutely fantastic! Grats.
MartiniOCP is offline   Reply With Quote
Old 05-06-2012, 07:03 AM   #14
euro_z
euro_z's Avatar
what a stunner, absolutely gorgeous!
Old 05-06-2012, 03:09 PM   #15
nugundam93
congrats on this great work!
olly olly oxen free
Dino 246GT bestmodeling Completed Projects / Gallery 11 08-04-2007 06:06 AM
98.83% finished fujimi dino 246gt drunken monkey WIP - Street 3 11-16-2006 08:52 PM
Completed: Dino 246GT (Fujimi) klutz_100 Completed Projects / Gallery 33 02-14-2006 06:51 PM
Another great kit from Fujimi: Ferrari Dino 246GT awaken1973 Car Modeling 2 12-14-2001 08:13 PM
