Go Back   Automotive Forums .com Car Chat > Buick > Skylark
Old 05-31-2011, 05:03 PM   #1
Bill Wilky
Water on floor of 1996 skylark
I have a 1996 Skylark. I have water on the driver side and the passenger side. I have looked for the hole by the steering column. I do not see a hole there. Has anybody found where the water is exactly coming in at from the firewall? There is a long seem that I can see from under the hood. Is this seem the issue?
Bill Wilky is offline   Reply With Quote
Old 07-14-2011, 04:32 PM   #2
Bill Wilky
Re: Water on floor of 1996 skylark
Poured black top crack sealer into cowl area down across the sterring column coming out of the firewall. It appears to have sealed the leak for now. Hopefully it continues to work through winter.
Old 09-19-2011, 11:51 AM   #3
jenhudd1171
I was told it was the heater core gone bad. How's your heater core? And I noticed this post was a long time ago... did you get your problem fixed?
jenhudd1171 is offline   Reply With Quote
Old 09-19-2011, 12:02 PM   #4
Bill Wilky
Mine is not the heater core. If it was that, the anti freeze would be low. My issue is only when it rains. I have slowed it up with lots of under coating spryed into the cow under the wipers. But its still leaking.
Old 09-19-2011, 12:10 PM   #5
jenhudd1171
OOOOhhhh I didn't realize it was only when it rains. Hmmm.... will have to see about that one. Sorry, no answers for you. Have a good day!
Old 05-12-2012, 03:59 PM   #6
leeannesbuick
mine does that to its a lake when it rains... mine has a startup problem has yours ever given you issues?
leeannesbuick is offline   Reply With Quote
Old 05-14-2012, 09:32 AM   #7
Tom_SF
Buick Owner
I gave up on that water leak issue a long time ago. Now I just stuff a towel under the firewall cover and change it.
Tom_SF is offline   Reply With Quote
Old 05-14-2012, 10:52 AM   #8
Tech II
If you have a "lake", then that carpet is soaked, and with the warm weather coming you will end up with a mildew smell.....only thing you can do is remove the seats, console, and remove the entire rug to dry it out....if you let the water stay under the rug, I guarantee you will have air bag problems, because the DERM(module for the air bag), sits on the fllor under the passenger seat, and the water will coorrode the harness and the module....
Now while you have the rug out......dry the floor of the car....remove hush panels under the dash(DR and PASS sides)......now have someone wet down the car thoroughly and you should get an Idea where the leak is coming from......could be a bad seam, but my money is on the fresh air inlet on the passenger side.....
As for the hard start, it may or may not be related to the water leak....water could corrode some grounds under the carpet......might even trickle down wire harnesses into contacts, causing corrosion.....
Tech II is offline   Reply With Quote
1996 SKYLARK Sparkplugs Bill Wilky Skylark 2 07-23-2007 10:28 AM
1996 skylark a/c question Roger0021062 Skylark 3 03-02-2007 08:55 AM
1996 Skylark water leak tawally Skylark 4 10-11-2006 10:22 PM
1996 SKYLARK can anyone HELP PLEASE? crazyoldergirlie Skylark 0 09-22-2005 04:33 PM
1996 skylark intake gasket/timing chain cover question Mark30 Skylark 0 08-19-2005 10:47 PM
