| Latest | 0 Rplys |
03-24-2011, 01:03 PM | #1 | |
2002 E150 air intake temp sensor
service code says it a bad sensor......... problem is manual doesn't talk about it.
Any ideas on where it is located??? |
03-24-2011, 02:10 PM | #2 | ||
Re: 2002 E150 air intake temp sensor
WHat was the code?? check to make sure there are no broken wires. autozne has a repair manual with pics, jsut need to register. hope this helps |
03-24-2011, 02:23 PM | #3 | |
is it the same as the MAS sensor?
03-24-2011, 02:43 PM | #4 |
03-24-2011, 02:52 PM | #5 | |
ill keep trying. every time i log in, i get booted. not sure where u are talking about. the only sensor that i see is the MAF one
03-24-2011, 03:28 PM | #6 | ||
Fig. ... carefully twist the sensor from the air cleaner outlet tube
To install:
03-24-2011, 04:49 PM | #7 | |
i dont have that set up. here is a pic of what i have. there is the MAF sensor and then nothing until u get to these two parts.
03-24-2011, 04:51 PM | #8 | ||
Should asked before, which engine do you have??????????? 5.8L And 7.5L Engines Fig. Typical IAT sensor mounting-5.8L and 7.5L engines
On California emissions equipped models, the IAT sensor is located in the air cleaner-to-throttle body tube. To install:
03-24-2011, 04:59 PM | #9 | |
4.2
03-24-2011, 07:36 PM | #10 | |
03-24-2011, 08:56 PM | #11 | |
Thanks for all yur help. I will look the part up and try to replace this week.
03-24-2011, 09:32 PM | #12 | ||
ebay item # 130500998042 180629072529 I entered motorcraft dy735 sensor and these showed up. Gets you a goood pic of part. |
The Following User Says Thank You to tempfixit For This Useful Post: |
draasch911 (03-24-2011)
03-24-2011, 09:45 PM | #13 | |
i will let you know how it turns out, thanks again
